neftis opened this issue on Aug 05, 2005 ยท 3 posts
neftis posted Fri, 05 August 2005 at 9:03 PM
Anyone knows if it's possible to change a texture in conjonction with a morphs dial(Texture changing in the same time as turning the dial)??That could be very useful for some facial expressions etc...Any clue??
nruddock posted Fri, 05 August 2005 at 9:26 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2320142
If it's for P5 or P6, there is likely to be a suitable node setup you could use.svdl posted Mon, 08 August 2005 at 5:45 PM
I'm not sure about textures - do you mean swapping out one texture for another, or maybe blending two or more textures? If so, it can be done using P5/P6 using a blender node - animate the ratio, then you can get a value parameter and slave it to a morph dial. If you're only changing RGB values, it's even possible in P4/PP: look for the KAMO Paraw freebie (forgot where I got it), that prop is using that trick to change the colors of the sails.
