bogwoppet opened this issue on Aug 06, 2005 ยท 10 posts
bogwoppet posted Sat, 06 August 2005 at 2:23 AM
It's been a while since I needed to render in Poser, most of my scenes are rendered in Vue. However I've tried to render a scene with M3 + Morphs and V3 + Morphs and some clothing @ 4000 X 4000.
I've always had problems with the Firefly engine hanging and tried the P4 engine instead which used to be ok with Poser 5 provided I kept the image size below 4090 X 4090.
The render began and then hung at the 'Rendering Scene' stage. I tried several times and even left the thing running overnight but to no avail.
I thought that this problem had been fixed with poser 6 but it seems not.
I have the latest update installed and rebooted before the render to clear memory. I checked the task manager and it indicated that Poser was working ok but I think it just gets into a loop and goes nowhere!
I'm not looking for a miracle cure here, although that would be nice :D I'm just trying to find out if this is a common problem and asking for your comments, suggestions or ideas regarding renders in Poser 6.
Thanks for taking the time to read this - much appreciated.
Tony
