Subject: poser 6 after some 'adds' and re-mix libraries....error!!!
softcris opened this issue on Aug 06, 2005 ยท 4 posts
softcris posted Sat, 06 August 2005 at 8:46 PM
Can you guys...tell me how to fix that small annoying problem in Poser 6 ...after I inserted some new adds on, files I had here from old Poser ProPack...and re-mix the libraries..to keep all tide and have better view of my files..since I thousand of Pose stuff to roll over..etc..' now when I render or start something new in Poser 6 pops-up that message..and usualy freezes an image I trying to render. Thanks guys :)
"'you shut up!  or I'll bring democracy to your country! "
Cris Galvão aka Softcris  - www.crisgalvao.com
(or softcris, SoftCris)
Rendering since 1997 and
at Renderosity since 1999.
OS Win 8.1     64 bit
xantor posted Sat, 06 August 2005 at 9:16 PM
If you copied folders from propack you might have inadvertently overwritten some poser 6 files with the older propack ones, and that could be causing the error. It is much safer to add the runtime than to copy all the files.
Casette posted Sun, 07 August 2005 at 1:57 AM
Maybe you used a folder the last time you closed Poser that you have moved Try this: -close Poser -open C:Program FilesCurious LabsPoser 6Runtimeprefs -delete LibraryPrefs.XML. -cross fingers -open Poser and ... fixed?
CASETTE
softcris posted Mon, 08 August 2005 at 7:43 AM
yes! fixed! but I had to re-instal the Poser 6 over the old instalation with all adds on already in...so now I know. Thanks guys. Have a nice day...
OS Win 8.1     64 bit
