DigitalDream666 opened this issue on Aug 09, 2005 ยท 13 posts
DigitalDream666 posted Tue, 09 August 2005 at 9:30 AM
Updates
Update to Version 5.08 - Build 277859
This update is available for Mac and Windows platforms. This update mostly corrects initial release version.
The following is a list of bug fixes and improvements included in this update:
Added support for Cornucopia3D content.
Improved Network Rendering.
Improved Pre-Animated Meshes:
Improved Inverse-Kinematics computation.
Improved edition.
Improved Scene Loading:
Improved incorporated textures loading.
Improved the loading of scenes containing empty meshes.
Removed incorrect messages when loading scenes.
Fixed saving and loading of Atmospheres without sun light.
Improved Rendering Engine:
Improved shadows render onto plants.
Improved rendering of transparent boolean objects and meshes with invisible volumetric materials.
Improved rendering of animation with strong distance blurring.
Improved Network Rendering with Multipass.
Improved Billboards lighting.
Improved Texture Anti-Aliasing over Billboards, Plants and EcoSystems.
Improved Rendering to Disk:
Improved strategy for very large renders.
Improved Camera post processing.
Fixed path names behavior.
Improved Edition:
Improved EcoSystem's populate function.
Improved edition of exported objects.
Improved baking of boolean objects and plants.
Improved Memory management:
Improved large images management.
Improved stability and memory management when editing and loading EcoSystem materials.
Improved Import/Export:
Improved RLA, RPF and DXF support.
Macintosh: Improved HDR export.
Improved OBJ import.
Improved terrain export.
Improved Poser 6 support:
Improved Poser objects manipulation,
Fixed bad names when importing on Windows,
Fixed ignored single frame option when importing on MacOS,
Improved compatibility with Vue 4 scenes containing Poser figures.
Improved Python:
Improved compatibility with HyperVue,
Corrected several scripts,
Fixed PixelFilter callback function.
Improved Batch Rendering:
Fixed a problem with single-frame render,
Added the ability to shutdown computer at the end of a batch process.
Improved Serial Numbers management for Pro Studio upgrades and Extra-Plants.
Macintosh: Fixed RenderCow on Tiger (a separate update can be necessary, see update description for more details).
Other minor interface fixes and improvements.
Message edited on: 08/09/2005 09:33
Mazak posted Tue, 09 August 2005 at 9:46 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12368&Form.ShowMessage=2368545
No 'update' it's a rollback... see post below ;)Mazak
Message edited on: 08/09/2005 09:58
agiel posted Tue, 09 August 2005 at 10:13 AM
Nope... available on e-on's website : Update to Version 5.08 - Build 277859 I would caution everybody to wait for a while and let some brave souls 'volunteer' to test this release before going ahead and installing it :) Now the question is.... who will it be ? :)
iloco posted Tue, 09 August 2005 at 10:17 AM
I don't care to install and test it but then again I seem to be the one who complains when find a problem and get others mad at me when I post them. O well its got to be done by someone or we never know what it will do or not do. Whats use releasing if we don't give it a go and see if any improvements have been made. :) Been beta testing since Vue Pro so why quit now.
ïÏøçö
Xiores posted Tue, 09 August 2005 at 11:25 AM
This is the same number version (277859) that was released at the opening off the Vue Store. Is this NEW or simply a rollback?
Ms_Outlaw posted Tue, 09 August 2005 at 12:52 PM
Think it's just a roll back. I had the three patches before, so already had this number. I redownloaded it's exactly ths same size as the other.
jc posted Tue, 09 August 2005 at 1:09 PM
I nominate agiel to test each new patch. He's such a nice guy that the forces of darkness demand he be made to suffer....bruhhaaahaaahahahahaha..... (no good deed shall go unpunished)
iloco posted Tue, 09 August 2005 at 1:43 PM
LMHO now its back to 277255. Must be a bug in the roll back system. I am now thinking it be good idea to quit beta testing and see if they decide on a good release. Ya agiel for being first to test all updates. :o)
ïÏøçö
agiel posted Tue, 09 August 2005 at 3:08 PM
Well... I wouldn't mind except... I am supposed to have a functionnal copy installed at all times so that I can test and answer questions from the forum :)
iloco posted Tue, 09 August 2005 at 3:25 PM
"lol" You care to tell us what build that is you are using........:o)))))
ïÏøçö
XENOPHONZ posted Tue, 09 August 2005 at 3:57 PM
I'll check back in from time to time to see how it's going.
dlk30341 posted Tue, 09 August 2005 at 6:07 PM
Now more rolling back/going forward until all this finalized. My puter is freaking out with all this. When the next update comes out, I'll be toodling around to different forums....waiting for positive feedback. Otherwise, I'll pass. Getting tired/disgruntled and disgusted/depressed.
Singular3D posted Sat, 13 August 2005 at 1:54 AM
Hope they soon sort their problems out. Was on the brink of upgrading from Vue5 Esprit to Infinite two month ago. Seems it's best to wait a bit longer. I already stumbled into the Poser5 problems, so I hesitated installing Poser6. Had never any problems with Vue4 d'Esprit so I'm a little bit surprised that they are working on additional features (store) instead of simply removing the bugs. This is not a cheap software, especially in Europe as already often stated...
