Subject: Tricolor Toon Shader
ashara opened this issue on Aug 09, 2005 ยท 7 posts
ashara posted Tue, 09 August 2005 at 5:57 PM
i'm trying to create a tricolor toonshader - a shader with the light and the dark color and a third color between the both. but i don't really make any progress... :( i would be very thankful for any suggestions or ideas!! by the way - i'm using poser 5
sixus1 posted Tue, 09 August 2005 at 8:12 PM
Check your messages here. :) --Rebekah--
mateo_sancarlos posted Tue, 09 August 2005 at 9:18 PM
Stewer, Compiler or Crescent have created some shaders that may do that, and the links are in either Freestuff or one of the old toon shader threads.
ashara posted Wed, 10 August 2005 at 7:42 AM
Attached Link: http://www.androidblues.com/shadetut.html
i have to explain my plan more in detail. i need the tricolor toon shader for creating a realistic skin shader. in the human skin shading tut for maya (http://www.androidblues.com/shadetut.html) is a tricolor toon shader used for adjusting the color tones of the light, the dark and the middle zone. light and dark have to be totally different colors (orange and blue) - which is unfortunately unreachable with the toon shader from stewer. also, the tricolor have to be smoothed - blended into each other like the spread setting in the poser toon shader. the toon shader is used beauce of its behaviour to lighting. the color for the areas in light can be another than the color for the shadowed areas... in the end i need a toon shader which has three different colors and the possibility to smooth.
ashara posted Wed, 10 August 2005 at 7:44 AM
Rendered without ToonShader applied. Looks quiet grey.
ashara posted Wed, 10 August 2005 at 7:46 AM
Rendered with ToonShader plugged into translucence and with the blender node and a small amount into diffuse. The red lined areas have to be adjusted.
ashara posted Mon, 15 August 2005 at 5:42 AM
nobody any idea??
