scoleman123 opened this issue on Aug 09, 2005 ยท 4 posts
scoleman123 posted Tue, 09 August 2005 at 8:40 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=887131&Start=1&Artist=scoleman123&ByArtist=Yes
facebook.com/scoleman123
scoleman123 posted Tue, 09 August 2005 at 8:42 PM
Useing only Bryce and a paint program
RodsArt posted Tue, 09 August 2005 at 8:52 PM
Create a subfolder under the Original, or seperate folder. Make screen shots through the procedure, from the first creation of the Texture file, transparency file ETC, all the way through the rendering and any post work. Once you get started you'll remember all the steps it took to make it, and that'll help plan it out. For each screen shot, name them in sequence. then create a note-pad file with a brief discription for each screen shot. You can avoid lots of text with arrows & frames for reference. Cruise through a couple of your favorite TUTs & use those a an example. Once you start, It'll all fall together. Have fun Looking forward to seeing it. ICM/Rod
___
Ockham's razor- It's that simple
UVDan posted Wed, 10 August 2005 at 5:09 PM Forum Moderator
to make labels and stuff with.
Free men do not ask permission to bear
arms!!
