Torulf opened this issue on Aug 11, 2005 · 5 posts
Torulf posted Thu, 11 August 2005 at 5:24 PM
I have poser6 and want to save a figure so the cr2 can be opened in poser5. How to do?
TG
wheatpenny posted Thu, 11 August 2005 at 5:42 PM Site Admin
Just save it as you normally do, and it will open in P5 (and P4 too). If iy uses any P6-specific features, those will be lost when you open it in P5.
When you open it in P5, you will get a "newer version" error message, but the file will still open. (to get rid of the error message, open the cr2 in a text editor, and where it says "version number", change it from 6 to 5).
Message edited on: 08/11/2005 17:44
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Jackson posted Fri, 12 August 2005 at 12:06 PM
When you save a cr2 in P6 it saves two files. One is the character, the other is the morphs. P5 won't read the morph file so you lose the morphs. If you go to the Misc tab in the Preferences dialog you can turn off "Use External Binary Morph Targets." Then P6 will save everything in the cr2 and you won't lose anything in P5. I think that's how it goes.
Torulf posted Fri, 12 August 2005 at 12:39 PM
Ar there any tutorial about how to edit cr2 files?
TG
RAMWorks posted Fri, 12 August 2005 at 1:03 PM
Thank you, good info to know! Richard ;-)~
---Wolff On The Prowl---
