Meshbox opened this issue on Aug 12, 2005 ยท 18 posts
Meshbox posted Fri, 12 August 2005 at 12:45 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1022589&Start=1&Artist=chikako&ByArtist=Yes
Ive posted a side-by-side render of our Halfling Village Guardhouse (which is for sale in our Renderosity store) rendered with two differing resolution texture maps. We are looking for feedback on a simple question: Does high rez always look better? I look forward to your feedback (and yes, we are looking to release a higher resolution graphics pack :-)). Best regards, chikako Meshbox Design http://www.meshbox.comBest regards,
chikako
Meshbox Design | 3D Models You Want
ClintH posted Fri, 12 August 2005 at 12:55 PM
Hi chikako, I think "A" looks better ... It seems to have more detail and a little less blur on the rocks. I HOPE thats the higher res version. LOL... Clint
Clint Hawkins
All my life I've been over the top ... I don't know what I'm doing
... All I know is I don't wana stop!
(Zakk Wylde (2007))
Meshbox posted Fri, 12 August 2005 at 1:34 PM
Not saying, at least not until Monday ;-) Vue 5 Esprit makes quite a nice testbed. Its rendering options are far better than Vue 4 and its pretty fast. Best regards, chikako Meshbox Design http://www.meshbox.com
Best regards,
chikako
jade_nyc posted Fri, 12 August 2005 at 2:07 PM
I vote for A as well.
jeffg3 posted Fri, 12 August 2005 at 2:13 PM
B looks better. I think A shows too much jpg compression in the texture. For all practical purposes they are indistinguishable - we would need to see close-ups.
thefixer posted Fri, 12 August 2005 at 4:10 PM
"A" no question, much more real looking. Looking forward to having the "egg on face".
Injustice will be avenged.
Cofiwch Dryweryn.
mamba-negra posted Fri, 12 August 2005 at 4:21 PM
It's hard to tell if the difference is due to more detail or to less on A. I actually like B better:) However, higher resolution options are a definite yes, since placing something interesting in inside the set and zooming in a bit would absolutely show artifacts if the texture were too small for the zoom. There are a great many otherwise nice models that just don't pass muster to me bacause their own promo shots highlight the weakness in texture. eric
Xena posted Fri, 12 August 2005 at 5:38 PM
The fencing looks better in B, yet the stone is lovely and sharp in A. A looks like B with a sharpen filter run over it :) I prefer B.
Giana posted Fri, 12 August 2005 at 7:15 PM
ooo, i much prefer "B"... i saved the image to my desktop and applied a variety of sharpening filters in Photoshop on the "B", and could easily replicate the look of "A"... i then tried softening up "A" to look more like "B" and while it is do-able, it takes a little more effort to not over-soften and to blend it... just my 2 cents... :))
orangeparty posted Sat, 13 August 2005 at 1:23 AM
I like B - Not because its really all that much better looking, but just because I like it. I know that's not all that helpful. Rob
Farside posted Sat, 13 August 2005 at 3:30 AM
It depends, first thing I almost always do when I make a purchase is to reduce the oversized textures that most merchants put out. This is a background item and would never be the main focus of any picture I would do, it would be there to create a mood or time period. As such, I'd reduce the textures if you went with A.
stonemason posted Sat, 13 August 2005 at 7:32 AM
Farside...if only everyone thought like you :P ..chances are this will be rendered close up..you'll have pics of someone standing by the doorway rendered at 2500x with a focal of 100mm...or a close up of someone in one of the windows.. IMO you can never make textures big enough..the end user can always scale down..but they can't go the otherway. make 'em big Cheers Stefan B looks better btw
dlk30341 posted Sat, 13 August 2005 at 12:04 PM
Ditto Stonemason.....I can always scale down. Nothing worse, than rendering up close & seeing blurred/pixelated textures.
Richard T posted Sun, 14 August 2005 at 5:27 AM
A like A best.
Porthos posted Sun, 14 August 2005 at 11:50 AM
B looks good to me!
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD
7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
aeilkema posted Sun, 14 August 2005 at 4:12 PM
High resolution textures only really look better in larger rendered scene. If your rendering size is much larger then the texture sizes you do use, it will show. But in smaller renderings it will not show that much at all.
Food for thought.....
stonemason posted Tue, 16 August 2005 at 3:15 AM
Chikako I was looking at the results of this test,in your gallery post you say : "Monday is here and the answer is: "A" is the high rez one at 4096x4096. Thanks for the feedback everyone! The original texture was "B" and it was upscaled " what's the point in upscaling the texture?..'A' maybe larger in scale but it is by no means better in quality since it's just 'B' made larger. you need to make the original texture large..(& you should never upscale a texture as has already been pointed out) btw,you have some nice models in your gallery. Cheers Stefan
aeilkema posted Tue, 16 August 2005 at 6:15 AM
Upscaling isn't high res at all. To really have high res the original texture needs to be size 4096x4096. The low res texture then is a scaled down from the high res one. You don't scale up low res to get high res, that's not high res at all, still low res. A scaled up low res texture will still look bad in a high res image. If you would sell a scaled up low res texture as high res texture you would actually be deceiving your customers. Try rendering a really large render with this scaled up so called high res texture and you will see the flaw in this practise.
