Subject: Annoying problem with P6
spedler opened this issue on Aug 15, 2005 ยท 2 posts
spedler posted Mon, 15 August 2005 at 2:34 PM
Whenever I use any of the rooms in P6 other than just the Pose room, on exiting Poser I get the following dialog box:
The instruction at "0x74706b41" referenced memory at "0x74706b41". The memory could not be "read".
Click on OK to terminate the program
This doesn't seem to cause any problems other than showing this dialog, but it's irritating to say the least! It also implies something's wrong which I'd rather was put right. It only happens if I use a room other than the Pose room - even just to enter another room is sufficient. The only thing I can see which goes along with this is that I keep getting that annoying HTML help window in all those rooms every time I enter one, and there doesn't seem any way to turn that off. I've tried re-installing, including the SR, but no luck.
Any help would be much appreciated!
Steve
zollster posted Mon, 15 August 2005 at 3:23 PM
i get a similar 1 sometimes when i shut down pc cos norton decides it wants to connect to the internet and i won't let it. i think its liveupdate
