Subject: Ingenue V and V3 Morphs
Svigor opened this issue on Aug 16, 2005 ยท 9 posts
Svigor posted Tue, 16 August 2005 at 10:07 PM
I inject V3's head morphs but none of them (at least the ones I want, the expression morphs, don't) work for IV. Also, I have a weird problem with V3's morphs. Where the heck are the expression morphs? I have to inject all head morphs at once to get the expression morphs into a character. I could've sworn there was a !V3 Expressions INJ folder but I'm not seeing it.
svdl posted Wed, 17 August 2005 at 1:24 AM
That's weird. I use IV a lot, and the expression morphs have always worked. That missing INJ folder could mean you accidentally moved or deleted it. Reinstalling the head morph pack will take care of it.
My gallery   My freestuff
Jim Burton posted Wed, 17 August 2005 at 10:48 AM
As svdi said, they aughta work, all the channels are there, the mesh is exactly the same, it isn't even scaled on IV (V3's too small head is just perfect on her!). I've seen Poser have problems and not run the morphs when the scene gets too "complicated" for it, maybe try loading th emorphs before you load any textures.
Svigor posted Wed, 17 August 2005 at 12:58 PM
Thanks fellas. Sounds like my expression morphs have gone AWOL. I wish I knew where the heck my poser disc was...
Svigor posted Wed, 17 August 2005 at 1:50 PM
Okay, I reinstalled the head morphs and it seems I was mistaken. There's no folder named "expressions" installed. In fact, judging by these folders and the morphs listed within, there are no expressions morphs. Still, injecting all the morphs at once injects the "non-existent" expression morphs too, and now they're at least working. Thanks again.
nruddock posted Wed, 17 August 2005 at 3:08 PM
The latest version of V3 has the expression morphs in the CR2 rather than as INJections, so you'll need to transfer them using MorphManger (or similar).
Svigor posted Thu, 18 August 2005 at 12:29 PM
Ah, okay that makes sense, though I should point out that the morph pack does inject them if you use the red all head morphs INJ.
svdl posted Thu, 18 August 2005 at 1:13 PM
There should be a INJ All Expressions pose in the morph pack, in the folder for All Head morphs. But that may be a leftover from the Victoria 3 initial release packs.
nruddock posted Thu, 18 August 2005 at 3:57 PM
I believe the lastest version of the head and body morph packs, have empty files for the included morphs, so that old INJ poses can find something (seen mentions in DAZ's forums).
