Strixowl opened this issue on Aug 18, 2005 ยท 13 posts
Strixowl posted Thu, 18 August 2005 at 1:40 PM
Anybody know the location of some Nuts,Bolts,Screws,Nails (props)? I know I've seen some.
TrekkieGrrrl posted Thu, 18 August 2005 at 4:51 PM
If all else fails, I can make you some...
momodot posted Thu, 18 August 2005 at 5:27 PM
Attached Link: http://fast3d.actionbabecentral.com/kathindex.htm
http://fast3d.actionbabecentral.com/kathindex.htm maybe?Mystic-Nights posted Thu, 18 August 2005 at 7:00 PM
Attached Link: http://mystic-nights.com/directory/index.php
Nuts & Bolts under Household - 3dsStrixowl posted Fri, 19 August 2005 at 2:21 PM
Strixowl posted Fri, 19 August 2005 at 2:22 PM
nruddock posted Fri, 19 August 2005 at 2:41 PM
Try the Group Editor.
If your lucky each item will have it's own group or material, which would make spawning individual props easy.
Otherwise you'll have to create the groups by hand.
momodot posted Fri, 19 August 2005 at 3:41 PM
You take the group editor tool. You select the prop. You frame it close on the front camera. You set preview to see-through wire frame. Your hit the button to create a new group. You drag over to select the element you want and use the main camera to see it is all selected but no part of the other elements are selelected, de-select as needed by dragging/clicking with Ctrl-key down. You can assign a material at this point. Hit the make prop button. Then you hit make new group and repeat. The texture UVs may have to be redone with UVmapper Classic. Hope this wasn't nonsense.
TrekkieGrrrl posted Fri, 19 August 2005 at 4:58 PM
Momodot, that was a very concise and clear explanation (at leat to me) on how to spawn a new prop with the Grouping tool! For some reason, the grouping tool has god a bad name, when it is in fact a BRILLIANT tool! I often use it , rather than UVMapper, to assign material zones to parts of a prop. The Grouping tool is easy and fairly intuitive, once you've let the intimidation go :o) And Strixowl, my offer still stands :)
momodot posted Fri, 19 August 2005 at 7:37 PM
ernyoka1, thanks.
Mystic-Nights posted Sun, 21 August 2005 at 9:51 AM
Attached Link: http://hometown.aol.com/helmzahn/meshes2.html
Strixowl posted Mon, 22 August 2005 at 1:02 PM
momodot I'm in total agreement with ernyoka1, your simple tutorial enabled me to separate the items into individual props. The group tool has always been very frustrating to me though I've had some success with it. Your lil toot opened up an area I never understood. Thank you. I's also like to thank Mystic-Nights for the great links you posted. Now my project is back on track :-) Sorry I didn't post back earlier, went to Seattle :-) Strixowl
momodot posted Mon, 22 August 2005 at 2:16 PM
Great. Thanks.
