Subject: having trouble logging into Renderotica? read this
pam opened this issue on Feb 24, 2001 ยท 7 posts
pam posted Sat, 24 February 2001 at 1:58 PM
Attached Link: Renderotica, with a new face
remove the "www." from your url. It worked for me, maybe it will work for you. pam
Fox-Mulder posted Sat, 24 February 2001 at 2:34 PM
Actually, it works either way. Many people may not be aware of it, but most domain websites don't actually require "WWW" in the front of the address. Try http://renderosity.com and it will work too...
Fox-Mulder posted Sat, 24 February 2001 at 2:39 PM
Also- if you use a current Explorer browser and type in just "Render" or "Renderosity", it should link you to the website AND, should also display the favicon.ico symbol in the address bar, which for Renderosity.Com is a green "R"...
pam posted Sat, 24 February 2001 at 2:51 PM
Fox dear, if I could get in either way, I would not have made the above post :-) Yes, what you say is true most of the time, but when DNS has changed, there can be a lag time before all works as it should. Atleast that is my guess. But just plain fact, I can get to http://renderotica.com, but I cannot get into http://www.renderotica.com :-)
Fox-Mulder posted Sat, 24 February 2001 at 3:37 PM
Then if they have changed their DNS server, which may be the case, a lag could be hours, days or even a week, depending upon when your regional ISP's or Internet Backbones do their updates. It works fine now where I am, which means the transfer has probably taken effect in most areas already...
TJ posted Sat, 24 February 2001 at 3:55 PM
I had to take the www out too pam to get in .. but my W's are working fine now.
spiderone posted Sat, 24 February 2001 at 6:51 PM
I hope mine work quickly. I can not reach 3d or renderotica.
