ravenfeeder opened this issue on Feb 24, 2001 ยท 9 posts
ravenfeeder posted Sat, 24 February 2001 at 7:15 PM
Fox-Mulder posted Sat, 24 February 2001 at 8:18 PM
I'll drink to that...
ookami posted Sat, 24 February 2001 at 10:12 PM
Great job! It definately reminds me of Ye Olde English Pub! You gonna post it? Or maybe make some more Olde English type buildings? =)
pdblake posted Sun, 25 February 2001 at 3:18 AM
How did you create the triangular parts in Poser. I create all of my props in poser but have yet to find a way to ,ake a triangle without importing it from somewhere else (like raydream)
ravenfeeder posted Sun, 25 February 2001 at 8:22 AM
Triangles are easy, once the light dawns, pdblake. You just add a cone, then set either the 'x' or 'z' dimension to zero. That gives you a flattened cone, otherwise called a triangle. From then on, it's easy, since adjusting the 'y' and the remaining parameters will give you the shape you want. Not sure if you can make a triangle with unequal sides (non-symmetrical). I haven't tried that.
pdblake posted Sun, 25 February 2001 at 9:50 AM
That's where the problem is, a proper triangle can't be made in poser with the props supplied. A flattened cone is just that, flat. You will run into problems if you need a triangle where the edges aren't hidden, rounded edges etc...
ravenfeeder posted Sun, 25 February 2001 at 9:55 AM
If you set one parameter to zero, the resulting figure is flat, with no rounded edges that I can detect. Setting the 'z' dimension to zero means it has no depth in that dimension, hence no rounded edges.
pdblake posted Sun, 25 February 2001 at 1:27 PM
Sorry, I maybe didn't phrase that right. I mean, what if you need some depth to it?
ravenfeeder posted Sun, 25 February 2001 at 4:45 PM
I see your point. I suppose you'd have to do two triangles, with boxes in between to form timbers, or something.
