ithkinlore opened this issue on Aug 23, 2005 ยท 2 posts
ithkinlore posted Tue, 23 August 2005 at 8:56 PM
OK, here goes. I was on here a few days ago, and I found it very helpful, so now I'm back. Muah-ha-ha-ha-ha!
.rsr picture files are used only with Poser4. .PNG files are used with the Propack.(This is what I have). Therefore, when you extract a file into the Propack with only an .rsr, it will show up in the library, but there will be nothing in the viewer window when you click on the picture to bring it up. I've also noticed that the files which do work have both an .rsr and a .PNG.
Here is my question. Is there a way to create a .PNG with p3dOexplorer, and if so, how?
Thanks again,
Ithkinlore
xantor posted Tue, 23 August 2005 at 9:08 PM
If you downloaded the plugins for p3do explorer as well as the program, in p3do explorer go to the directory where the rsr files are then go to the tools menu and select convert rsr to png. Then click on rsr to png in the convert part and then click ok, it will say how many files were converted. Propack should automatically convert the rsr files to png.
Message edited on: 08/23/2005 21:09
