LostinSpaceman opened this issue on Aug 24, 2005 ยท 26 posts
LostinSpaceman posted Wed, 24 August 2005 at 2:41 PM
Attached Link: http://www.lostin3d.com/
Davros for the P4 Male by Xantor Located in the Doctor Who Forum under his own sticky download thread! Free Membership Required for Access.xantor posted Wed, 24 August 2005 at 3:00 PM
The Davros figure works in poser 6, so it probably works in poser 5, too, but you need the poser 4 male and his sweater for the file to work.
alt1701 posted Wed, 24 August 2005 at 3:10 PM
wow thanks this is great
xantor posted Wed, 24 August 2005 at 3:39 PM
I am glad you like it.
Redfern posted Wed, 24 August 2005 at 3:42 PM
WOW! That actually works amazing well! Here's a thought, try applying the texture to the P4 male based character named Dr. Morpheen, a freebie at RuntimeDNA. It has a variety of morphs to purposely create "ugly mugs". A few tweaks should approximate Davros' oddly shaped skull. Xantor, have you attempted to create a Tom Baker texture in a similar fashion? I know Cobalt years ago used the Poser 4 male to create a surprisingly effective 4th Doctor. If you can do with Baker what you've done with Molloy, you'll have legions of fans worshipping at your feet! Sincerely, Bill
Tempt the Hand of Fate and it'll give you the "finger"!
LostinSpaceman posted Wed, 24 August 2005 at 3:50 PM
I'll bow down to that idea! ;) I loves my Tom Baker Doctor!
xantor posted Wed, 24 August 2005 at 3:54 PM
I havent tried making a tom baker character yet. The davros texture was made using photos and trying to make the parts fit.
xantor posted Wed, 24 August 2005 at 4:23 PM
LostinSpaceman posted Wed, 24 August 2005 at 4:32 PM
Very nice! What he really needs now is a nice 3D Eyeball prop for the middle of his forehead. I haven't been able to get the texture displaced enough to make the eye pop out yet.
Redfern posted Wed, 24 August 2005 at 7:06 PM
LostinSpaceman posted Wed, 24 August 2005 at 7:40 PM
I'm thinking that Dork or Dr Morpheen just need a nice "BigBrain" morph to really do his bulbous head justice. I might work on that in Zbrush if I stay motivated long enough. ;) I found a cyber Eye prop in my runtimes that must be from your set Bill. I've got a Mimic clip animating him in the background right now or I'd fiddle with your props on him.
JHoagland posted Wed, 24 August 2005 at 8:17 PM
Very cool! That's really the P4 male? I never would have believed it! But, where are the Daleks? Davros was never seen without the Daleks around. :) --John
LostinSpaceman posted Thu, 25 August 2005 at 2:43 AM
Attached Link: http://www.lostin3d.com/Flash/Davros.html
You want Daleks? Watch this:LostinSpaceman posted Thu, 25 August 2005 at 2:44 AM
PS for some reason my AVI to SWF converter cut's the sound off prematurely. SwishVideo the latest build.
xantor posted Thu, 25 August 2005 at 7:20 AM
I have made a dalek, it is more like the older ones but not a specific show one, it is not available yet.
I wanted to make a big brain morph for the davros figure but I am not so good at making morphs, posers tiny scale doesn
t help either.
I also realized after the figure was available that the turtle neck would look better for the davros jacket.
Message edited on: 08/25/2005 07:22
LostinSpaceman posted Thu, 25 August 2005 at 2:28 PM
LostinSpaceman posted Thu, 25 August 2005 at 2:29 PM
If you want I can swap out his Sweater for the Turtleneck as well.
xantor posted Thu, 25 August 2005 at 4:16 PM
I sent you a pm at lost in 3d about this.
LostinSpaceman posted Thu, 25 August 2005 at 7:21 PM
Your updated file is online with the readme file added. Now stop loosing my email address you big goof. ;)
xantor posted Thu, 25 August 2005 at 9:36 PM
ok The newer file has the turtle neck sweater and the grey base and the bases` shape has been fixed, too ( in the picture above you can see it is slightly wrong ). For the benefit of others reading the thread.
LostinSpaceman posted Fri, 26 August 2005 at 9:17 AM
LostinSpaceman posted Fri, 26 August 2005 at 9:56 AM
Oh, His head has a Taper setting of -20 in that latest image but you'll have to set it yourself if you want it that way. He comes in the zipfile with no taper setting.
xantor posted Fri, 26 August 2005 at 2:09 PM
LostinSpaceman posted Fri, 26 August 2005 at 2:35 PM
Hrm... that it does. Need to check my runtime I obviously loaded the wrong one.
LostinSpaceman posted Fri, 26 August 2005 at 2:43 PM
xantor posted Fri, 26 August 2005 at 2:53 PM
To get the eye and headpiece you could use the one from vanishing point. It seems a bit pointless to remake it when the vanishing point one is there already.
