Subject: Please HELP Nellie !
stahlratte opened this issue on Aug 25, 2005 ยท 2 posts
stahlratte posted Thu, 25 August 2005 at 6:49 PM
A while ago momodot sugested a PT-Vicky/NEA hybrid, so I created Nellie:
Image hosted by Photobucket.com
Not my first hybrid, so I thought this one would go quite straightforward like the other ones. LOL.
Unfortunately NOT.
While changing PT-Vickis upper and lower necks into a single new one and adding NEAs lacrimal and teeth bodyparts, something went wrong with the cr2, as Im unable to tweak the neck and heads joint parameters.
And I CANNOT find that "!&/% mistake I must have made. :-(
So could PLEASE someone who really knows his way around cr2s check Nellie out before I put her up for download ?
Many thanks in advance.
stahlratte
svdl posted Fri, 26 August 2005 at 4:17 PM
I'm afraid I can't help you directly, since I don't have Vicki PT. But maybe I have an idea where the problem comes from. You merged the upper and lower neck groups into one, and probably deleted a bone. But the old joint parameters in the cr2 might still be in place, referring to a bone that no longer exists. I could check the cr2 for you, but I can't test it.
My gallery   My freestuff
