Forum: Carrara
Subject: Edit the Moon?
chuckerii opened this issue on Sep 06, 2005 ยท 3 posts
chuckerii posted Tue, 06 September 2005 at 12:43 PM
Anyone ever try to edit or change the moon image that appears in "Sky" or "Realistic Sky?" Just curious if it is an image file hidden somewhere that I could edit or if it's embedded in the program. Thanks. Chuck
ren_mem posted Sat, 10 September 2005 at 3:41 PM
Bit Late..don't know if you got this figured out, but if you click on the scene in the hierachy tree then you can edit the "realistic sky" under atmosphere and there are moon settings there. I suppose you can also place a primitive that has been altered as a shader over that area. Playing w/ transparency channel. You could also do some work post process. Really depends on what you are going for.
No need to think outside the box....
    Just make it invisible.
chuckerii posted Sat, 10 September 2005 at 10:32 PM
Thanks for the reply... Yes, I know that you can edit the moon settings in Realistic Sky, but I was wondering if you could actually access and edit the image that they use for the moon - which is not editable in the program itself. Just one of those "Is it possible?" type questions, since I couldn't find a way on my own. As for my scene, I did actually go with a sphere primitive and used the alpha channel in it's shader to fade my planet off into the sky and clouds. Chuck
