UKmac opened this issue on Sep 15, 2005 ยท 9 posts
UKmac posted Thu, 15 September 2005 at 12:20 AM
DJB posted Thu, 15 September 2005 at 1:23 AM
I think the background way back there would be lighterif IR. I tried this a few times too and thought why buy a filter.Sure does show it in a different perspective.It is a good image for this.
"The happiness of a man in this life does not consist in the
absence but in the mastery of his passions."
MaydaMason posted Thu, 15 September 2005 at 5:39 AM
it works very good for a software simulations... but some parts of this pic (light and shadows) looks as a negative shot... this is not correct... and the foliage must to be more white... a real infrared filter is a good choice! but for a software work looks beautiful!
tibet2004uk posted Thu, 15 September 2005 at 8:13 AM
I don't think I could make the difference to be honest but that's cos I know nothing of IR filters so to me, this looks spot on! But I think the opinion of people who actually use IR filters will be much more valuable here! I really like this nonetheless!
LostPatrol posted Thu, 15 September 2005 at 9:24 AM
No expert on IR, looks good to me, I have seen several different ways to do this with PS/PSP, I agree the foliage would be whiter on real IR. My friend shoots a fair bit if IR and I have noticed on his shots how white the plant life is almost to the point of glowing. I know on some Digi cams the sensor has a filter to reduce IR, with the exception of the Canon 20Da which doesnt have one as it is for stellar photography. So if your camera cant see IR, I dont know if an IR filter would do anything? Richard (Onslow) was talking about this the other day on Zackos filters thread. Anyway I like this shot, the pillars look good, and there is also an IR tute in this months Digital photography user (landscapes) issue 80 Simon
TwoPynts posted Thu, 15 September 2005 at 9:55 AM
Very cool shot but I agree with May that some spots almost look like a negative (ie. the tops of the columns). The tree on the left would be lighter too, and the background could use some slight lightening. Otherwise, a great software solution to IR. :) Here are 4 of my attempts at it: http://www.renderosity.com/viewed.ez?galleryid=861105 http://www.renderosity.com/viewed.ez?galleryid=856127 http://www.renderosity.com/viewed.ez?galleryid=834701 http://www.renderosity.com/viewed.ez?galleryid=830798
tvernuccio posted Thu, 15 September 2005 at 12:14 PM
Pretty cool, Steve! When using an infared filter though...like May said, the foliage should be very white. Sure does make a neat effect though! :)
UKmac posted Fri, 16 September 2005 at 12:54 AM
Thanks all. Will try again, not sure how to make just certain areas whiter, back to trying again. Steve
Georges_H_Hoens posted Fri, 16 September 2005 at 4:56 AM
Your shot is pretty cool....
About IR, I did experiment it a few days ago with a 720mstr at 50% filter.
It is not so easy to have a good IR result. You need a strong amount of light to have a neat shot, elsewere the shot is blured.... Considering the sun direction, the angle of shot is also a factor of good result. The exposure setting is quite complicate because you can't read correct indications on your cam.. I used a speedshutter between 1 and 4 seconds... Without tripod it does not work.
Message edited on: 09/16/2005 05:00
