Forum: Vue
Subject: Ecosystem question
mstnicholas1965 opened this issue on Sep 21, 2005 ยท 4 posts
mstnicholas1965 posted Wed, 21 September 2005 at 1:28 PM
Does anyone know if this is possible? Let's say that you have created a number of items ( in case playing cards) and when you created and saved them they were set up vertically ( stanging up on edge) but you want them to be laying down horizontally, face up (as on a table) when used in the ecosystem. Is there any way to do this on the fly or do I need to re-save the object in the correct orientation? Appreciate any insight. Thanks. MDT
DVcreator posted Wed, 21 September 2005 at 3:08 PM
What Version of VUE , In VUE4 I would rotate on the the objects axis and then drop object to surface.
mstnicholas1965 posted Wed, 21 September 2005 at 3:44 PM
It's Vue 5 Infinite. I wouldn't be an issue to rotate the object axis, but there are 52 of them and hence would be time consuming. Any way to do it globally?
lingrif posted Wed, 21 September 2005 at 6:22 PM
I'm not a real eco guru, but you could experiment with the eco system setting on the Scaling and Orientation tab - Direction from surface - and set that to perpendicular. That should work.
www.lingriffin.com
