bjoru opened this issue on Sep 27, 2005 ยท 7 posts
bjoru posted Tue, 27 September 2005 at 9:22 AM
Friend of mine exported a Poser6 figure as a PZ3. The figure loads fine in my Poser4, but none of the morphs work, I can't get the figure to smile! What is wrong?
xantor posted Tue, 27 September 2005 at 9:44 AM
If your friend switches off use external morphs and saves the pz3 again then it should work.
EnglishBob posted Tue, 27 September 2005 at 9:50 AM
The only way you can legally use Poser 6 figures in Poser 4 is to own a copy of Poser 6. Anything else is a breach of copyright. PZ3s don't carry a copy of the figure geometry anyway, so I assume you must have copied the decompressed OBJ from your friend's machine.
xantor posted Tue, 27 September 2005 at 10:10 AM
It could be a figure that they both have (not one of the original poser 6 figures).
Little_Dragon posted Tue, 27 September 2005 at 6:42 PM
PZ3s don't carry a copy of the figure geometry anyway .... Not by default, at any rate. The geometry can be embedded manually, though.
xantor posted Wed, 28 September 2005 at 1:30 AM
One of the older versions of poser 4 could save pz3 files with the geometry embedded but it got changed later.
bjoru posted Wed, 28 September 2005 at 10:32 AM
EnglishBob is right, I got OBJ-file along with the PZ3. I did not know this was a copyright-problem. If this is right, I'll try no further...
