Subject: P6 problem: expressions for V3
blud opened this issue on Sep 29, 2005 ยท 8 posts
blud posted Thu, 29 September 2005 at 1:05 PM
I don't know if this is a rehash of an problem that has been discussed before, but I can't seem to get P6 save the expressions on V3 - let alone anyother morph target setting. It happens with all of my head morphs.when I save and reopen all are reset to zero.
Is this an issue with P6 that anyone else has experienced or do I have a corrupt file in there some where?
Message edited on: 09/29/2005 13:06
blud posted Thu, 29 September 2005 at 1:31 PM
Turns out that the standard V3 saves fine - all morph targets. However V3 with Andruino's hip replacement (MPG), something is up with the cr2 where it will not save morph target settings. Anyone know of a fix?
randym77 posted Thu, 29 September 2005 at 1:34 PM
You could try disabling external morphs. That seems to fix a lot of problems with P6.
SamTherapy posted Thu, 29 September 2005 at 2:39 PM
Never, ever use the PMD or external morph targets options. God only knows why they were set as the defaults.
blud posted Thu, 29 September 2005 at 2:52 PM
Thank you...Thank you.....and Thank you again. That has solved my issue. Just what the heck is the external morph target thingy anyways? It'll just ruin your day.
SamTherapy posted Thu, 29 September 2005 at 3:03 PM
It's a way of saving your morphs so they can't be used ever again... er, no... It's a way of saving your morphs so they fuck up your files no matter what you do... er, no... It's a way of saving your morphs to somewhere else so you have a greatly reduced filesize. Unless you try to reload it, because - hey, guess what, kids - they got to be saved somewhere! Cynical, moi? Whatever, it's a bag of shite. :D
Jules53757 posted Thu, 29 September 2005 at 3:30 PM
With Arduinos MPG, look into the cr2 or pz2, since Poser 6 SR1 obviously a hidden statement is required. If you find the hip morphs at actor hip :x , you only have to add after namexxx a new line with hidden 0, you will find the dials after using the morph,
Ulli
Jules53757 posted Thu, 29 September 2005 at 3:31 PM
With Arduinos MPG, look into the cr2 or pz2, since Poser 6 SR1 obviously a hidden statement is required. If there is no statement, poser interpretes this as hidden 1, without SR1 as hidden 0. If you find the hip morphs at actor hip :x , you only have to add after namexxx a new line with hidden 0, you will find the dials after using the morph,
Ulli
