starmage opened this issue on Oct 01, 2005 ยท 13 posts
starmage posted Sat, 01 October 2005 at 4:16 PM
Only your mind limits yourImagination. Let it free.
geep posted Sat, 01 October 2005 at 6:09 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1620991
What's that ... you say that your props are plagued with excessive polys? Try Doc Geep's "Magic Box" for fast, Fast, FAST relief !!! cheers, dr geep ;=]Remember ... "With Poser, all things are possible, and poseable!"
cheers,
dr geep ... :o]
edited 10/5/2019
starmage posted Sun, 02 October 2005 at 1:17 AM
I'm modelling in 3DS Max, not Poser :) I've concentrated too much on the detail is the problem and I forgot to Use instance rather than copy (it's pretty much a basic shape copied a lot of times).. I'll fix it no worries :)
xantor posted Sun, 02 October 2005 at 7:07 AM
As dr geep said, simpler parts don`t really need a lot of polygons.
starmage posted Sun, 02 October 2005 at 7:13 AM
Wish it was that simple.......... lol But the grooves are cylindrical, not square. This is where the problem is being caused. I'm currently in the process of recreating the base part in low poly. I'm actually aware of what needs and what doesn't need low polys. I've been doing some modelling for a game so I've had a bit of a practise at this :) Should be sorted soon.
starmage posted Sun, 02 October 2005 at 7:32 AM
Sorry that last post seemed a little grumpy.... Think it comes from me breaking the mesh a few times already tonight! Grrrrrr..... But here's a close up of the base board structure so you can see what I mean by it not being cubes. The furrows are cylindrical which is adding a lot of poly's to the count. I'm working on reducing those and then using instances because this is the basic building block of the design (I used Copy last time).
starmage posted Sun, 02 October 2005 at 7:34 AM
xantor posted Sun, 02 October 2005 at 7:47 AM
I couldn`t see a lot of the detail on the first picture, it looks almost like an alpha channel. It would be easier to see the details if the object was a lighter colour.
starmage posted Sun, 02 October 2005 at 7:54 AM
Yeah that's okay :) Am working on it at the moment. Coming along much nicer now and a lot smaller on the poly count :) This time I've left the pecies seperate so it's a bit easier to work with the mes (deleting polys).
starmage posted Sun, 02 October 2005 at 8:54 AM
geep posted Sun, 02 October 2005 at 9:33 AM
" ... I'm modelling in 3DS Max, not Poser :)"
Oh, sorry ;=[ ......... I thought this was the Poser Forum.
;=] That's lookin' real good. Edited to remove all: None, Nudity, Violence, Both, TOS violations, cuss words, dirty jokes, obscene material, and all TOP SECRET information. Message edited on: 10/02/2005 09:35
cheers,
dr geep ... :o]
edited 10/5/2019
bagginsbill posted Sun, 02 October 2005 at 10:28 AM
I recently made a prop of a framed painting with a nice rounded frame entirely out of a single poser one-sided square. Here is a piece of it showing in a scene I'm working on.
starmage posted Sun, 02 October 2005 at 10:29 AM
