gagnonrich opened this issue on Oct 02, 2005 ยท 12 posts
gagnonrich posted Sun, 02 October 2005 at 1:02 PM
My visual indexes of Poser
content are at http://www.sharecg.com/pf/rgagnon
mateo_sancarlos posted Sun, 02 October 2005 at 1:44 PM
Maybe your grey wasn't exactly (128,128,128). But the concentric ridges on the smooth bump are probably caused by jpeg banding, an artifact of turning a smooth gradient into a compressed jpeg image.
spedler posted Sun, 02 October 2005 at 1:56 PM
The exploding box problem is (if I understand it correctly) due to the way Poser likes its displacement maps. Other 3D software usually takes 50% gray as the midpoint - i.e. no displacement - with black indenting and white extruding. Poser, on the other hand, takes black as the no displacement point and any lighter colour will therefore extrude - so, the exploding box. To get round this, plug your displacement map into the value_1 input of a math_function node set to subtract, with value_2 set to 0.5. (This assumes the background of your map is 50% gray - you may need to tweak this value slightly.) This will subtract 0.5 from each value input from the map, and means that black now has a negative value and will indent, and white will still extrude (although it has a lower value).
Steve
geep posted Sun, 02 October 2005 at 1:57 PM
cheers,
dr geep ... :o]
edited 10/5/2019
JohnRickardJR posted Sun, 02 October 2005 at 2:20 PM
I wish there was a way to force the edges to remain joined. It's all very well to be be able to alter your greyscale so that 50% (or whatever) is no displacement, but that only works if every edge on your shape is flat. What if you want a ridge that runs around four sides of the cube?
maclean posted Sun, 02 October 2005 at 4:11 PM
stewer posted Sun, 02 October 2005 at 4:37 PM
gagnonrich posted Sun, 02 October 2005 at 6:21 PM
Thanks for the info! I'm still playing around with settings, but it doesn't look as if the displacement is going to offset the fact that the texture doesn't look very realistic close-up. I'll have to play around with other things to see what can be done to improve how it looks. It's so irritating how useless the Poser manual is for the Material Room. There isn't even any mention that black is zero displacement.
ju8nkm9l posted Sun, 02 October 2005 at 9:15 PM
I must say, Macclean's carpet image is one of the most realistic scenes I've seen coming from DAZ Studio (not just the carpet, but the floor and walls). I'm very impressed! Do you mind telling us what model you used for the room (floor, walls and blinds), MacClean?
maclean posted Mon, 03 October 2005 at 3:57 PM
Thanks for the kind words. Without breaking into a commercial, the scene is my own product, called Home One Apartment at DAZ. It's a 5-room apartment and that's the living room. The render was done with the default lighting. I just moved one of the lights to shine on the carpet. The carpet is one of 50 props/figures in an upcoming expansion pack for the apartment (living-room contents), although the pack can be used with any house at all. Probably the reason it looks good is that I've been making separate poser and DS versions of my products for the last year. So, if you use DS, you don't need to tweak anything. Get the DS version and it's all set up and ready to render. mac
unzipped posted Wed, 05 October 2005 at 7:57 PM
bookmark
Niles posted Wed, 19 October 2005 at 7:49 PM
marked
