barrowlass opened this issue on Oct 07, 2005 ยท 4 posts
barrowlass posted Fri, 07 October 2005 at 9:44 AM
..... OK, I've used P4/PP, P5 and am now on P6. I love the material room for changing textures on clothing etc. I often use RDNA's freebies for this. However, I'd like to make some of my own but haven't the first clue on how to go about it (Materials 4 Dummies would be nice). Is there a relatively straightforward tutorial for this? Thanx for any help. BTW I have Paint Shop Pro 9 with which to create the actual textures.
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
thefixer posted Fri, 07 October 2005 at 12:18 PM
Bookmark!
Injustice will be avenged.
Cofiwch Dryweryn.
starmage posted Fri, 07 October 2005 at 4:53 PM
You'll need something like UVMapper (http://www.uvmapper.com). Assuming you don't already have a template for the object you want to create the material for then you'd load the .obj into UVMapper and save the image created as a template. All that's left is basically colouring in the template and applying the texture to the item you want in Poser 6.
Only your mind limits yourImagination. Let it free.
barrowlass posted Sat, 08 October 2005 at 4:01 AM
thanks, I have UV Mapper and have played about with it - will see what I can come up with ;-)
