Subject: Need help with M3 shorts
sturkwurk opened this issue on Oct 09, 2005 ยท 8 posts
sturkwurk posted Sun, 09 October 2005 at 6:27 PM
I have these shorts in my M3 clothing library... I don't even remember where I got them... I think they may have been a daz freebie at some point? Here's the problem, I finally need to use them, but when I go to load them from my library, they fail to show up... I don't get any errors, they just don't show up. The geometry reference seems fine, there's actual geometry where there should be. (they are in a Daz folder) Does this ring any bells?
I came, I rendered, I'm still broke.
SamTherapy posted Sun, 09 October 2005 at 6:45 PM
Yep, it does. I can't remember the solution to the problem, though. I think they were corrected and offered again. They were a DAZ freebie, I can remember that much.
sturkwurk posted Sun, 09 October 2005 at 6:55 PM
Thanks, I'll try over at the Daz fourm and see if that can rattle loose an answer. Doug
Lucca posted Sun, 09 October 2005 at 9:33 PM
Have you tried deleting the RSR file? When Poser says that it cannot find the geometry, the problem is often a corrupt rsr file.
sturkwurk posted Sun, 09 October 2005 at 9:43 PM
Great Idea, I forgot about trying that one. Rats, didnt work I did find that the cr2's reference body2 instead of 1, but even after changing all of them, it still didnt work. Doug
MarianneR posted Mon, 10 October 2005 at 9:29 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1453818
Here's how to fix it with UV-Mapper.
profotograf posted Mon, 10 October 2005 at 4:20 PM
The textures look like ones done by RichardT, I'd check with him on where it was from. Greetings, Antonio
Greetings from Germany
ProFotograf
My PoserAddicts
randym77 posted Mon, 10 October 2005 at 5:14 PM
Those are the DAZ shorts, which were a temporary freebie. There was a bug in the original release. They issued a fixed version later, but a lot of people didn't know about it. You can fix it yourself in UVMapper, but it's kind of a pain.
