Forum: Carrara
Subject: Particle shader question
Primitive_Dave opened this issue on Oct 13, 2005 ยท 7 posts
Primitive_Dave posted Thu, 13 October 2005 at 6:42 PM
Hey -- I've been playing with the particle shader and I can't quite get it to do what I want. I would like to set up the particle fountain so that the particles appear bright and fade as they age -- like a fire, for example. However, the particle shader seems to only apply to the ENTIRE particle fountain. It cycles through the color range from bright to dark to bright again. This is not what I want. I would like the base of the fire near the emit area to be bright and trail off as the particles travel away from it -- the way you'd think it would. Does anyone know how to achieve this? I'd appreciate any suggestions. Thanks!
SF to LA: From June 1 to June 7 2007 I will be riding my bicycle 545 miles to help support people living with HIV/AIDS. Please visit my homepage: http://www.aidslifecycle.org/6010
misha123 posted Sun, 16 October 2005 at 6:24 PM
You can use my pLife plugin shader instead. http://www.associatedfx.com/plugins.html The particle shader with the application does not currently function as you would expect. Mike
Primitive_Dave posted Mon, 17 October 2005 at 11:08 AM
Thanks Mike! I have just downloaded the plugins, so I haven't had a chance to try them yet, but I appreciate it! Dave
wolf359 posted Mon, 17 October 2005 at 12:49 PM
How does one load these plugins in Carrara pro4????
My website
Primitive_Dave posted Mon, 17 October 2005 at 1:10 PM
Are you on Mac OSX? If so, you control-click on the application icon and select 'Show Package Contents.' Then just drag the folders into the extensions folder...
wolf359 posted Mon, 17 October 2005 at 1:36 PM
thanks!!!
My website
Moonglow posted Tue, 25 October 2005 at 12:08 AM
Thanks Mike.
