Acadia opened this issue on Oct 17, 2005 ยท 10 posts
Acadia posted Mon, 17 October 2005 at 11:11 AM
say." - Ghandi
ockham posted Mon, 17 October 2005 at 11:26 AM
Looks like you're using P4 or 5. The 'grid' is P6's new way of showing the ground. In 4 or 5, you could get the same effect like so: Select the Ground. On the top menu, hit Display:Element Style: Wireframe. If you want this to be permanent, you'll probably have to save Preferences....
Acadia posted Mon, 17 October 2005 at 11:37 AM
Hmmm, I am using Poser 5. I just tried what you suggested. I closed Poser and reopened it to be sure. Then I picked the ground, went to Display, Element and picked WireFrame... and nothing happened. The pose window still shows like above. Also, I only want the ground to show as wire, not the figures I add to the window. Is that possible? Anyway, I still have a blank Pose window with no floor grid showing.
say." - Ghandi
ockham posted Mon, 17 October 2005 at 11:38 AM
Did you hit Ctrl-G to show the ground?
ockham posted Mon, 17 October 2005 at 11:43 AM
Acadia posted Mon, 17 October 2005 at 11:44 AM
Figured it out!!! I had to go to Display, Guides, Ground Plane first. Then when I did what you suggested it worked! Thanks so much.
say." - Ghandi
R_Hatch posted Tue, 18 October 2005 at 1:36 AM
Shift+CTRL+3 will give you this display style for the ground (or whatever you have selected when you hit Shift+CTRL+3). It's very handy for moving things around when you have large props in the way.
Acadia posted Tue, 18 October 2005 at 1:52 AM
I'm a drop down menu kind of gal. :) I only know 3 Window's shortcuts. CTRL ALT DEL; CTRL Left Click; and SHIFT Left Click. Everything else I do by drop down menu. I'm sure that Poser and my other programs have a million keyboard shortcuts, but I don't know any of them.
say." - Ghandi
Acadia posted Tue, 18 October 2005 at 1:58 AM
I have another question. If I apply tile to the ground, how do I get rid of it if I don't want it anymore? What I ended up doing was turning off the ground plane again.
say." - Ghandi
lmacken posted Tue, 18 October 2005 at 5:49 PM
w/ Gound selected; Display/Element/Texture Shaded.
