Subject: Full Figured Clothes
nugpot opened this issue on Oct 21, 2005 ยท 3 posts
nugpot posted Fri, 21 October 2005 at 8:29 AM
Thanks to all who answered my message. Sounds like Wardrobe Wizard is the way to go. Where/How can I obtain it ?
Acadia posted Fri, 21 October 2005 at 8:47 AM
Attached Link: http://www.philc.net/WardrobeWizard.htm
You can get it here. There is also a support forum set up here: http://www.philc.net/forum/index.php?sid=437b69a3ee15f62f2d72ea95da73bc1b The support and personal attention given to each person is astounding. Quick replies for help. I think PhilC and Kamilche should be given nobel prizes for this poser plugin. It's by far the most valuable tool that I have purchased for any program that I have.
Acadia posted Fri, 21 October 2005 at 8:54 AM
Oh, and one nice thing about this program is that you can use other people's .dat files and not have to go through the analysis process, which also means that you won't need the figure that the clothing is made for provided you have: 1. the clothing 2. the .dat file from the clothing analysis process. If you have those items, all you do is put the clothing on the figure you want it to fit, and then run "convert to", and the clothing is fit to your figure. Of course if you don't have and can't find someone's .dat file, then you will have to analyze the clothing yourself, and that will require the figure the clothing is made for. At Phil's site, there is a section set up that has loads of files for already analyzed clothing. You don't get the clothing or any of the clothing files... just the analysis data. Also, once an item of clothing is analyzed, you never have to analyze it again so long as you have the .dat file in the analysis folder. If you lose it or delete it, then you have to reanalyze it. What that means is that you can analyze your hair and clothing and have all of the .dat files in the analysis folder, and then just convert to whatever figure as you need to. This saves on a ton of room. Simply load your figure, apply the clothing and run the conver to feature. Voila. Takes seconds after the clothing has been analyzed.
