Forum: Vue
Subject: Displacement mapping in V Infinite
pjlumby opened this issue on Oct 23, 2005 ยท 6 posts
pjlumby posted Sun, 23 October 2005 at 10:38 AM
Does anyone know how to apply kutters displacement mapping tutorial to Infinite? (http://www.renderosity.com/tut.ez?Form.ViewPages=291) When I attempt it I get hopelessly lost editing the function in the distribution settings.
Thanks,
sittingblue posted Sun, 23 October 2005 at 10:39 PM
Infinite makes the process much simpler. In order to match the texture map with the terrain, you need use the object-parametric mapping mode for the terrains texture inside the Material Editor. The map will correspond with the terrain, though you map need to rotate the map 180 inside the function editor.
Charles
Cheers posted Mon, 24 October 2005 at 9:23 AM
"The map will correspond with the terrain, though you map need to rotate the map 180 inside the function editor." I've never been able to understand why this hasn't been sorted out...when doing complex maps it always catches me out. Why can't all maps just be applied with the same rotation?! One of the quirks of Vue I suppose. Cheers
Twitter: Follow @the3dscene
Veritas777 posted Wed, 26 October 2005 at 7:33 PM
Attached Link: http://www.altuit.com/webs/altuit2/VueLab/TerrainMapping.htm
You also might want to take a look at Chipp Walter's tutorial on this subject.
I was able to take this terrain map and...
Veritas777 posted Wed, 26 October 2005 at 7:38 PM
... and bump map it!
But it IS a real pain-in-the-rear to have to go through all the steps required- especially since in Bryce 5 bump mapping a terrain is as simple as bump mapping any other object!
This is why I'm ranting about E-On supporting Geo-Referenced Terrains! If they Geo-Reference Terrains they will de-bug the whole mapped terrain process in Vue- and we will even have SEA LEVELS that actually go where they are supposed to- like the way the old VistaPro does it so easily...
pjlumby posted Thu, 27 October 2005 at 5:15 PM
Thanks for your help, got it sorted. Now all I need to do is produce an image I'm finally happy with......
