Anim8ScoobyDoo opened this issue on Oct 29, 2005 ยท 4 posts
Anim8ScoobyDoo posted Sat, 29 October 2005 at 7:24 PM
Hi. I'm interested in purchasing DM's Pose Boutique 4 for Aiko 3 which is located on the Renderosity site at (http://market.renderosity.com/softgood.ez?ViewSoftgood=38451). I know this will work in Poser but will the poses show up and work with DAZ Studio as well? I own DAZ but I don't own Poser so whatever I purchase would need to work within DAZ Studio as a stand alone. Thanks for the help.
SpottedKitty posted Sat, 29 October 2005 at 8:02 PM
Should work OK in D|S. The only plain pose settings that won't work are the occasional ones that change or fix a figure's Joint Parameter settings. D|S uses a different system for working joints, even for imported Poser-format figures, so the JP info will (I think) just get ignored.
RHaseltine posted Sun, 30 October 2005 at 8:52 AM
You may get a warning that the pose is "out of limits". Most figures have limits set for how far the parts will bend or twist, to keep them close to anatomical realism, but by default Poser ignores them; as a result amny poses go beyond the set range of motion. In general it's best to choose "Keep limits on" and see how the pose looks, then try reapplying with limits off if the result is no good.
MatrixWorkz posted Sat, 06 October 2007 at 9:16 PM
Hrmmm... this must be why the joints I edited in Poser for the Jupiter 2 Complete landing gear doesn't work the same way in DS as it does in Poser. Can you edit the joints in DAZ Studio?
