Subject: Poser 6 Python Problems
Starkdog opened this issue on Oct 30, 2005 ยท 12 posts
Starkdog posted Sun, 30 October 2005 at 1:59 AM
I have no idea what is going on with Python in Poser6? I can't get Real Skin Shader to work. It ignores all materials. RSS works fine in Poser5. I tried some of PhilC's and even Ockham's scripts, and I keep getting errors, or nothing happens. This really sucks, especially since I want to get Occlusion Master, and the Poser6 Realism kit. Perhaps the Python wizzards can help me. TIA, -The Starkdog
ockham posted Sun, 30 October 2005 at 2:15 AM
If nothing at all is happening even on the simpler scripts, most likely it's an installation problem or even something corrupt in Poser.exe itself. Simple scripts usually don't use any of that extra equipment in the DLLs or LIB folder. What sort of error messages are you getting?
My python page
My ShareCG freebies
ninhalo5 posted Sun, 30 October 2005 at 2:47 AM
just a thought.. before using the skin shader are you selecting the main light first? if you don't select that then you will get an error. J
face_off posted Sun, 30 October 2005 at 3:49 AM
I've had this issue reported once or twice. Reinstalling Poser fixed the problem in all cases. Also, if you have separately installed python, it may be conflicting with PoserPython, however in this case it gives a TCL error.
Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
Starkdog posted Sun, 30 October 2005 at 11:06 AM
Here is a pic of what is happening in Real Skin Shader. The script runs, and I can tweak dials, but when the script is run, it ignores all materials. The only Python on my machine is Poser5 and Poser6. -Starkdog
Starkdog posted Sun, 30 October 2005 at 11:13 AM
This is the error I'm getting while using PhilC's Clothroom Presets script. Once the pants are clothified, I go to the Mat room and apply the material. A python script is supposed to tweak the dynamics settings, but I keep getting this error when applying the mat and script. -Starkdog
PhilC posted Sun, 30 October 2005 at 12:04 PM
Are you sure you have the scripts installed into the correct folders. Mine certainly contain preset paths in them. That last error message is indicative that Poser Python can not find the required file. The ClothRoomPresets.py files need to be in Runtime:Python:poserScripts:PhilC:Cloth Room Presets
Starkdog posted Sun, 30 October 2005 at 12:22 PM
Thanks PhilC, I had it in my Downloads/Runtime/Python/PoserScripts.... directory. I put it in the right spot and it works GREAT!! I keep forgetting that you put specific paths in your scripts. -Starkdog
agape posted Sun, 30 October 2005 at 1:02 PM
Hey Starkdog...when I looked real close at what you have selected in your Poser window, I didn't see a light selected. I use the RealSkin Shader all the time. It will only work if you have the figure selected and your main light. Did you have a light selected, renamed with something starting with "M"? Take a look! jaebea
Starkdog posted Sun, 30 October 2005 at 1:18 PM
Hi Agape, I had re-named one of my lights to Main. I selected Terai-Yuki and the Main light, and ran RSS. For some reason, it gives me errors as noted in the top pic. It doesn't matter which light I select, even if it is the strongest light, I still get these errors. BTW, what is the newest version of RSS? Mine is 1.1 Perhaps this could be a problem? -Starkdog
face_off posted Sun, 30 October 2005 at 3:27 PM
Attached Link: http://www.physicalc-software.com/forum/viewtopic.php?p=30#30
The script is ignoring meateials Head and Body - since you haven't updated it to work with Terai Yuki 2. See above link for details.
Blog
Facebook
Starkdog posted Tue, 01 November 2005 at 12:07 AM
Face_Off, Thanks for the info about adding material zones to the script. Everything is working fine now. My Python problems are finally solved. -Starkdog
