Subject: Poser 6 and DAZ Victoria/Michael
szymas opened this issue on Nov 01, 2005 ยท 7 posts
szymas posted Tue, 01 November 2005 at 7:38 AM
Maybe I don't understand, (though I've been using Poser since Version 4) I just purchased Version 6 upgrade and uninstalled version 4 and 5 from my PC. after reboot I installed version 6, rebooted.. I tried to install DAZ Victoria and Michael but when the screen comes up to say where to install them, I only get in the dropdown, DAZ Studio 1.0, poser 4 and Poser 5.. Any idea on the workaround to install the characters correctly? Thanks ahead of time..
vilian posted Tue, 01 November 2005 at 7:41 AM
It's P5 install option you need.
Outdated gallery over at DeviantArt
Fics at FanFiction.net and Archive of Our Own (AO3)
stallion posted Tue, 01 November 2005 at 7:50 AM
if you already uninstalled P5 then change the 5 to 6 in the install because Poser use the same path on all versions unless you changed it. I do this when I purchase new items from daz some do not give a P6 option so when the screen come up I just delete the 5 and put 6
do this any time it ask for P5
IMHO you should have kept P4 and P5 installed since you can link to their runtimes from P6
You might as well PAY attention, because you can't afford FREE speech
Tyger_purr posted Tue, 01 November 2005 at 8:01 AM
DAZ's install is pre programmed. It isnt detecting your 4 and 5, it is just preset to offer D|S, p4 or p5 installs. I'm not even sure it makes a diffrence which one you choose. i use P5 but it still gives me RSRs but not PNGs.
My Homepage - Free stuff and Galleries
szymas posted Tue, 01 November 2005 at 8:30 AM
Thanks for the quick replies! Stallion, I deleted them since I really needed to do some house cleaning! I removed over 800 Megs of files I've probably used once.. ;) Thanks again!
thefixer posted Tue, 01 November 2005 at 10:52 AM
Usually on the DAZ installer there is an option for manually selecting the folder, just type in poser6. That's what I do and it works just fine! thefixer, poser coord.
Injustice will be avenged.
Cofiwch Dryweryn.
tastiger posted Tue, 01 November 2005 at 1:52 PM
That DAZ installer is a pain isn't it? You select Poser 5 and it still installs all the P4 and PP stuff anyway..... Why bother with the option?
The supreme irony of life is that hardly anyone gets out of it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz   3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
