rainlondon opened this issue on Nov 01, 2005 ยท 13 posts
rainlondon posted Tue, 01 November 2005 at 9:59 PM
I am trying to make one of the figure transparent. Everything is fine, until I try to do this to the head. When I go to make head transparent, You can see all things inside the head. Gum, teeth, etc. It looks awful. So I go and make all the rest of the stuff even more transparent, but doesn't really help much. Is there a way to make these parts invisible? I don't see anywhere to do so like you can with all the rest of the props. I am using P6 if that makes any difference. Please help if you can! Thanks!
warning202 posted Tue, 01 November 2005 at 10:15 PM
If it is just used for a still image, I would take the character into a program like Gimp (or photoshop, for those with money) and make the figure semi transparent, then paste him in a new layer over the scene and clean it up.
leather-guy posted Tue, 01 November 2005 at 10:43 PM
Alternative method - Compose and render the scene first without the figure. Apply the render to a one-sided square primitive and position to fill the screen in exactly the same aspect as the original. Set the square to partial transparency in whatever percentage suits your purpose - try 50% and adjust as needed. Place the figure where you want it, and re-render with the semi-tran parent scene superimposed over the figure. Might produce the effects you want, with a bit of trial and error. Good luck with your image. . .
ockham posted Tue, 01 November 2005 at 11:22 PM
Yup, Poser does really strange things when you make a figure semi-transparent. Worst of all is that parts like ears and noses can show up at weird angles, because they're seen "from inside" which throws Poser into a confused tizzy. The only decent solution, as the other answers said, is to render the object by itself, opaque as usual, then use 2D layers to put it back into the scene with transparency. You might want to mix a white mask onto it as well.
DoomedProphet posted Tue, 01 November 2005 at 11:51 PM
Or you could go into the material room and make all the offending parts 100% tranparent...
MungoPark posted Wed, 02 November 2005 at 12:34 AM
Export the parts you need as an object - reimport and make transparent
tastiger posted Wed, 02 November 2005 at 1:10 AM
The supreme irony of life is that hardly anyone gets out of
it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz 3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
mkmike posted Wed, 02 November 2005 at 2:11 AM
Or you can use this pose "Fallen Angels, Restless Wraiths" from cyllan http://market.renderosity.com/softgood.ez?ViewSoftgood=40771 It's very interesting and been on my wishlist for awhile now :P
RawArt posted Wed, 02 November 2005 at 10:06 AM
Attached Link: Davey Jones Ghost
You could also try Davey Jones Ghost at DAZ which has a ghostly transparent figure http://www.daz3d.com/shop.php?op=itemdetails&item=1697weirdass posted Wed, 02 November 2005 at 11:23 AM
Attached Link: http://www.weirdass.net
Use the grouping tool to apply a new material to the internals of the head. Mitchrainlondon posted Wed, 02 November 2005 at 1:21 PM
thanks everyone, I am going to give all these a shot, see which works best for me.............!
Foxseelady posted Wed, 02 November 2005 at 1:49 PM
Can't you make teeth and such hidden in the heirchy editor? (I know my spelling stinks lol)
bigjobbie posted Thu, 03 November 2005 at 10:36 AM
no, teeth and mouth bits need transparencies applied to make them disappear.
