Aioria opened this issue on Nov 02, 2005 ยท 7 posts
Aioria posted Wed, 02 November 2005 at 6:03 AM
diolma posted Wed, 02 November 2005 at 8:25 AM
To get the effect you want, the mesh must a single object. That means that the "small planes" MUST share vertices with the "big plane". If the small planes already line up exactly with vertices in the big plane, then you might try "weld identical vertices" when importing... Cheers, Diolma
Aioria posted Wed, 02 November 2005 at 9:12 AM
Thanks.How to weld identical vertices in the Rhino?
ockham posted Wed, 02 November 2005 at 11:15 AM
diolma posted Wed, 02 November 2005 at 2:19 PM
Actually, you can do as ockham suggested directly in Poser, by using the grouping tool on the cloth square (See Dr. Geeps tutorials for examples..) I, too, would have started out by using bigger square and cutting out the unwanted bits (it's just the way my mind works..) It'd probably be quicker and easier to start again using that approach..:-)) Cheers, Diolma
ockham posted Wed, 02 November 2005 at 3:09 PM
Excellent point!
Aioria posted Thu, 03 November 2005 at 3:35 AM
Thanks ockham&diolma.Now,I can do it.
