Subject: Rigging Problem in Poser 6
Letterworks opened this issue on Nov 04, 2005 ยท 2 posts
Letterworks posted Fri, 04 November 2005 at 10:28 PM
I on't believe I've run accross anything on this problem before so I thought I'd post this here to see if anyone has seen it and/or has any suggestions.
Looking at the attached picture. This shows a suit with attached feet. In both picture the suit is conformed to Figure 1. The upper picture show the conformed suit as it works when imported from the Poser Lirary. Note that the toes of the suit don't conform.
In the lower picture I've simply taken the suit back into the Setup Room and RE_INSTALLED the bones from it's own CR2 file, then back in the Pose Room I re-conformed the suit to the same figure.
I've tried to resave the item to the Library once I'd got it working again but it did the same thing the next time I tried to use it.
I've noticed this problem with a couple of other items but it doesn't seem to happen everytime or with every clothing item.
The Donor CR2 file is a version of the original figure file emptied of it's original morph info and generally cleaned up as per Secrets of Figure Creation with Poser 5.
It may be something I'm doing, but it's begiinning to drive me nuts, so any help would be gratefully accepted.
Thanks
mike
Message edited on: 11/04/2005 22:28
R_Hatch posted Sun, 06 November 2005 at 1:38 AM
The only thing I can think of is to open the CR2 in a text editor or CR2Builder and see that everything looks normal.
