Subject: underwater in P6?
PapaBlueMarlin opened this issue on Nov 06, 2005 · 12 posts
PapaBlueMarlin posted Sun, 06 November 2005 at 3:02 PM
I plan on using IBL to creat a water scene with the sea creature freebies from CP. How can I create an underwater appearance in P6? I was thinking of doing depth of field or changing the atmosphere, but I'm not sure if anyone has tried this before.
ockham posted Sun, 06 November 2005 at 3:37 PM
Here's a simple approach: just a one-sided square in front of the fishies, acting as a screen. Lights in front of the screen. I added a Spots node to give it some shimmer; probably should have made the effect stronger.
My python page
My ShareCG freebies
dialyn posted Sun, 06 November 2005 at 5:54 PM
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=15125&ViewImage=3#Image
You can also use a light gel to give an effect of light through water effect. Look at the second and third page of quim2001's product...there is a watery effect there, to show you what I mean. (There may be other light sets that do the same thing; this is the one I happen to be familiar with--and one can do one's own). If you're not a purist, you can add the effect in postwork. dreamsosweet has a nice [tutorial](http://www.sweetdreamsdigital.com/WaterTut.html) for Paint Shop Pro, if anyone is interested.
Virtua36 posted Mon, 07 November 2005 at 10:05 AM
Maybe the caustic light gels in Runtimedna's Poser5 freestuff are useful.
danamongden posted Mon, 07 November 2005 at 10:10 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2233511
The link is to a thread earlier this spring where I was attempting to get an underwater effect for a V3. It includes some info on doing an underwater light using procedural shaders in P5/6.
dialyn posted Tue, 08 November 2005 at 4:17 PM
Attached Link: http://www.runtimedna.com/mod/filelib/index.php?section_id=18
I know it is too late, but RuntimeDNA had some caustic light gels for Poser 5 that would work in Poser 6. They are free and someone else might find them of use if they haven't discovered them already. PapaBlueMarlin...did you delete the graphic? I went to look and I got a message that it was removed. :(
PapaBlueMarlin posted Tue, 08 November 2005 at 5:11 PM
Yes, I removed it since I wasn't completely satisfied with it. It's still in my gallery at RDNA though.
dialyn posted Tue, 08 November 2005 at 5:24 PM
Very nice. I look forward to seeing the finished product. Thank you!
PapaBlueMarlin posted Tue, 08 November 2005 at 7:49 PM
Attached Link: http://www.runtimedna.com/mod/ophoto/index.php?photoid=1359
here it is over at RDNA...
Mec4D posted Sat, 15 December 2007 at 1:29 PM
Attached Link: DOWNLOAD HERE
Don't forget about my Poser7 under water FREEBIE!!!
Cath
_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
bagginsbill posted Wed, 15 April 2015 at 11:18 AM
Resurrected from the lost wiki link.
Rance01 posted Wed, 15 April 2015 at 2:08 PM
http://www.ranquist.net/tutorial/UwTest.htm
Made this after reading some of bagginsbill posts.  The link from the page leads back here to an older forum thread on the subject.
 Best Wishes,
Rªnce
