Subject: M3 "Heavy" morph misses left leg!
ptrope opened this issue on Nov 11, 2005 ยท 5 posts
ptrope posted Fri, 11 November 2005 at 10:08 PM
Has anyone else had this problem? I'm using M3 SR2, and when loading the "Heavy" morph, either for the full body or the left leg itself, it doesn't work, even though the morph applies to the right leg and to the rest of the body. I looked at the deltas and the CR2 of M3, and the actors are at least named identically, so I don't know where else to look to try to fix this. BTW, adding "heavy spandex" also fails to affect the left leg ... :-( I haven't checked other body morphs, yet ...
Little_Dragon posted Fri, 11 November 2005 at 10:17 PM
There are two updates ... one for Michael himself, and another for his body morphs. Make certain you've installed both.
Also, if you're using Poser 4/Poser Artist, you might need to delete the blMilMan_m3.rsr from your geometries folder so that Poser will build a new one.
ptrope posted Fri, 11 November 2005 at 11:05 PM
That seems to have worked! Thanks!! :-D
Inspired_Art posted Fri, 11 November 2005 at 11:46 PM
WOW! That's looks like me from the neck down, heheheh
Eddy
RWB64 posted Sat, 12 November 2005 at 1:26 AM
Hope you saved a copy of the fouled up morph. Twist that leg a bit and you would have a good rendition of a number of deformities that whither a leg. Not trying to be macabre but who knows when you need a crutch leaning extra in a scene. Cheers, RWB64
