isacatcar1 opened this issue on Nov 13, 2005 ยท 6 posts
isacatcar1 posted Sun, 13 November 2005 at 5:50 PM
Attached Link: http://www.turbosquid.com/FullPreview/Index.cfm/ID/193769
Can this trophy be created in poser? Or does anyone know where I can find one that is not so expensive.Thank you in advance for your help.
kuroyume0161 posted Sun, 13 November 2005 at 6:18 PM
If you can get a free football, you could then use a cube prop with scaling and tapering to create the base. It may not be an exact match, but something close. Then it is all a matter of setting materials to get the nice shiny chrome. :)
off.
-- Bjarne
Stroustrup
svdl posted Sun, 13 November 2005 at 6:24 PM
You can make the football by scaling a hires sphere in one direction. The seam can be made using displacement mapping (if you have Poser 5 or 6), or by using a magnet on a small band of polygons. The curvy effect of the base can also be done by using a magnet on a tapered cube.
isacatcar1 posted Sun, 13 November 2005 at 8:29 PM
The football is easy, because I bought the Football gear from daz. I still cant get the bottom part to work.
kuroyume0161 posted Sun, 13 November 2005 at 11:16 PM
Yeah, I checked and there is no taper on the primitive props in Poser.
off.
-- Bjarne
Stroustrup
ockham posted Sun, 13 November 2005 at 11:37 PM
Attached Link: http://ockhamsbungalow.com/MiscProps/stand.zip
Try this... The ZIP includes an OBJ file and a UV template so you can turn it into a prop with your own texture.
