kromekat opened this issue on Nov 15, 2005 ยท 16 posts
kromekat posted Tue, 15 November 2005 at 9:58 AM
..Anything broken for the other Mac OSX users out there since updating to SR2? I am on 10.3.9 on a dual G5 2.5, but am intending to go to Tiger on it as soon as I get time. Cheers / Adam
Adam Benton | www.kromekat.com
ariannah posted Tue, 15 November 2005 at 10:09 AM
bookmark
I have the same config as yours, Adam, so want to bookmark this in case anyone replies. I haven't yet updated to SR2 or Tiger. I'd like to see how others are doing before I take the leap.
Standing by.....~arry
I dare you, while there is still time, to have a magnificent obsession. --William Danforth
texboy posted Tue, 15 November 2005 at 11:39 AM
Poser 6 SR2 works great with OS X 10.4.3; seems to be more stable, renders faster, and is more compatible with Vue 5 Infinite. So far, so good! regards from texboy Texas Number One!
wolf359 posted Tue, 15 November 2005 at 12:37 PM
it breaks philc's wonderful Wardrobe Wizard Clothing converter plugin so i had to go backs to SR1 to do some conversions this past weekend. But phil &Co have already sent me a WW update patch but i have not had time this week to re-install SR2 and try the patched version of Wardrobe wizard to see if its fixed.
ariannah posted Tue, 15 November 2005 at 12:46 PM
wolf - thanks for the info on the WW. I had read about the SR2 probs here (I think) and know Phil sent Kamilche a heads up regarding the issue. Hopefully all it will take is a few changes to have our WW back up and compatable. texboy - thanks as well for your feedback regarding Tiger and P6. I wasn't sure how it was working out. I may have to wait to update to Tiger until Bryce catches up....
kromekat posted Tue, 15 November 2005 at 1:08 PM
Thanks for your input folks! - downloading it now. :) Adam
dbutenhof posted Tue, 15 November 2005 at 3:13 PM
I've had time to try 3 separate scenes that had foiled SR1; renders had reliably crashed every time, and the body part and material popup menus were completely fried. With SR2, the popup menus work flawlessly. One of the 3 scenes still crashes, unfortunately; but the other 2 render nicely. So it's not perfect, but it's a big improvement.
RadDad posted Tue, 15 November 2005 at 4:05 PM
I am working on a 17" PowerBook, 1.5 GHz, 1 Gig Ram... 10.4.3. works fine except if I switch to another application, and come back, the background window disappears, along with the floating palettes. If you save the file at that point, the issues come back along with the file when you relaunch it. On the other hand, it does not crash as much...
stewer posted Wed, 16 November 2005 at 3:16 AM
works fine except if I switch to another application, and come back, the background window disappears, along with the floating palette Read the readme. You have Unsanity's WindowShadeX installed which is messing with some some system functions that Poser relies on.
RadDad posted Wed, 16 November 2005 at 6:29 AM
Thanks - I will deactivate that and let you know if it works, or not.... I talked to a tech guy at e-frontier. He said he had the same problem on his PowerBook - but not on any other machines. I will pass this on to him so he can post to his FAQ.
kromekat posted Thu, 17 November 2005 at 7:31 PM
Thanks folks - works fine for me so far! :)
wolf359 posted Fri, 18 November 2005 at 6:02 AM
Just FYI Adam idont know if you ar a wardobwzard user but I have beta tested the wardobe wizard update for Philc&Kamilche and it has fixed the problem and is fully functional again under SR2 ;-)
RadDad posted Fri, 18 November 2005 at 6:35 AM
Follow up - the WindowShade fix worked - shame on me for not reading to the bottom of the Read Me.
ariannah posted Fri, 18 November 2005 at 12:38 PM
wolf - I just checked PhilC's forums but didn't see the patch for MacOSX and SR2 available yet. Any info on when this will be available? TIA! ~arry
wolf359 posted Fri, 18 November 2005 at 2:10 PM
There was a post on the DAZ forums from kamichle,the WW co- creator, that the update will be posted within the next day or two keep an eye out i guess
kromekat posted Fri, 18 November 2005 at 4:22 PM
Hi Wolf, No I know nothing about Wardrobe Wizard! - wassat then? Adam :)
