ddaydreams opened this issue on Nov 16, 2005 ยท 11 posts
ddaydreams posted Wed, 16 November 2005 at 11:51 PM
Once upon a time I saw a tutorial on how to make light rays in photoshop, I can't remember if it was here at rosity or out there in the vast webiness somewhere. In this tut someone just used a whiteish blurry brush, did a quick squiggle then applied some effect or blur on the whiteish squiggle.I'ts a short tutorial. Very simple and looks great. Anybody seen this.I want to give it a try
Please Help.
Frank Hawkins/Owner/DigitalDaydreams
Frank Lee Hawkins Eastern Sierra Gallery Store
My U.S.A eBay Graphics Software Store~~ My International eBay Graphics Software Store
Hoofdcommissaris posted Thu, 17 November 2005 at 3:06 AM
Without extensive tutorial searching, I would recommend trying 'motion blur' in the direction of the rays of the squiggly painted blurry brush thing. And maybe play around with the layer blend modes (and copies of the layer set to another blend mode and maybe gaussian blurred). There are lots of ways I can think of, but the approach depends on the look you are after.
tantarus posted Thu, 17 November 2005 at 8:41 AM
If you need kind of the rays that coming through the clouds. Here is just a quick idea, make triangle selection and fill it with gradient (transparent to black) then soften with gaussian or blur the edges with blur tool, then change the color with H/S to yellow, and finally lover the opacity. Its just the idea :) Tihomir
Open your mind and share the knowledge!
TrulyMadly posted Thu, 17 November 2005 at 9:04 AM
Yep, tutorials are good, but if you want to follow step by step instruction to make something like a light ray, may be is easier to look for an action in photoshop to do just that. But the most satisfying experience is still when you discover your own technic by experimenting. :)) Me personally, I found blending mode ( colour dodge ) most useful when it comes to imitating lights.
Hawkfyr posted Thu, 17 November 2005 at 10:05 AM
Attached Link: http://www.unc.edu/~haraszti/volumetrictut.html
Was it this one by Feri? Tom“The fact that no one understands you…Doesn’t make you an artist.”
ddaydreams posted Thu, 17 November 2005 at 3:18 PM
THanks for the help all, keep it coming if you are reading this and know of a link, the tutorial I'm looking for had rays coming in from upper left to the mid bottom and may have been lighting a forest scene or room interier I 'm just not sure. It only involved a few pictures to get the point across.
Hawkfyr posted Thu, 17 November 2005 at 3:58 PM
Attached Link: http://www.andysplace.cwc.net/drag6.htm
You Might mean Hobbit's tutorial. Got to this link: http://www.ans-graphics.com/ and select "Tutorials". I've included a link above to an image. Is this the one? Tom“The fact that no one understands you…Doesn’t make you an artist.”
ddaydreams posted Thu, 17 November 2005 at 10:46 PM
Thanks hawkfyr, but the light rays at your link here were done using Bryce. But that's ok I use Bryce to, so one more Bryce trick up my sleeve.I'm still looking, If I find it before someone else I'll post a link here.
Raptura posted Sat, 19 November 2005 at 11:57 AM
I think I know what you might be looking for. There is a tutorial just like what you described here - http://www.deviantart.com/deviation/11629793/ I hope that helps!
ddaydreams posted Sat, 19 November 2005 at 9:15 PM
Nope that's not it. But thanks. If I cant find the one I'm looking for I'll probably use that one. I'm still looking for it, there is a lot of ways to do this out there.
jmjbriones posted Fri, 25 November 2005 at 2:41 PM
You can try at www.good-tutorials.com Suerte
