Subject: Freebie update/and problem - SciFi TV Character
billy-home opened this issue on Nov 21, 2005 ยท 4 posts
billy-home posted Mon, 21 November 2005 at 5:44 AM
First off, I must say a big thank you to revric, who spotted a problem with the zip and the cr2 for the above freebie.
First the zip contains 2 lots of materials, only one set is needed, the set that unzips into the materials folder in Runtime/Libraries.
The second problem with the cr2 is a bit worse, I have 2 versions of the figure on my system, I put the cr2 for one of them with the obj file for the other in the zip, the cr2 is looking for an obj file called "Dalek-2005.obj", the one that installs is called "BH_Dalek-2005.obj", the quickest way to fix this is to just change the name of the obj file to the correct name, the file is in located in Runtime/Libraries/Character/BH-Dalek-2005. The other is to download the updated zip file and install that over again
Sorry to those who have downloaded this for any incovenience.
Cheers
Billy
Message edited on: 11/21/2005 05:44
billy-home posted Mon, 21 November 2005 at 5:56 AM
One other thing I forgot to mention is the site this is on has a bandwidth limit, so there may be times when it seems to be down, it isn't it's just reached it's limit for the month is all, I'm looking for an alternative site to host it, when I do I'll update the links accordingly. Billy
artbyphil posted Mon, 21 November 2005 at 7:08 AM
cheers, this looks great can't wait to have a go with it:)though as you said the bandwidth seems to have run out at the mo:( Ill keep an eye on it.
Message edited on: 11/21/2005 07:09
Little_Dragon posted Mon, 21 November 2005 at 6:44 PM
I'm looking for an alternative site to host it ....
zUpload.com
