Forum: Bryce
Subject: fur effects in bryce
cobwebdesignz opened this issue on Nov 25, 2005 ยท 21 posts
cobwebdesignz posted Fri, 25 November 2005 at 5:14 AM
Hello all, I am a little new to bryce and do most of my modeling in Truespace, but I love the textures in bryce. I have been asked to produce a set of images for some childrens books and I now find that I need to have fur, I have tryed to use a hair plugin in truespace but it came out looking like a 1990's computer game, so I tryed some texures in bryce. this is ok, but real fur effects would look so much better. I am a poor man so I can not afford Maya or anything like that that has fur built in. are there any plugins for bryce that can produce a fur effect? If so what are they? Please help, thanks
Dann-O posted Fri, 25 November 2005 at 5:35 AM
Fur? Well Pdjy or Flak would know. If it is really needed I would go for a volumetric version. Use a volume material version of the object that is slightly larger than the original object as to which volume material to use that is another story. If you really master the Deep texture editor you can get something done. One of the things I have been doing to models in Wings is to select verticies and do an extrude on them(usually free and then pull the extrusion in the wanted direction) . I really don't knwo how to do it. You could get a good fur type releif using some bump map like Golden bump. What is the current polygon count of the models. If noth to high then you can go the Wings route. Bryce can handle a lot of polygons but wings is a bit more limited. Good luck. Good luck. The volume approach there is a grass volume shader that might work. Volume materials take a long time to render But the results are often worth it I almost always use them.
The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the person next to me.
pidjy posted Fri, 25 November 2005 at 6:21 AM
I've been trying to get some fur effect with bryce.. with no result as the volumetric textures only gives a good result when applied to a primitive "sphere or cube".. If you need to get some fur on a character, then you got to make it using "postwork" with a software such as photoshop.
pidjy posted Fri, 25 November 2005 at 7:08 AM
Here is how I usually do I make render of a shape with a basic volumetric cloud shader. I import the image in photoshop, make a new layer without the background and i start to give the "fur" effect using the "finger" tool (with a 50% pressure) I start from the border and finish in the center of the "character" Then I draw the eyes (or I imort an image with the corresponding mask image) I add some shadow on the fur with a smoth brush.
It's quiet long to do but you may get the result you want.
Sans2012 posted Fri, 25 November 2005 at 8:26 AM
LMAO! pidjy, that is classic lol.
I never intended to make art.
TheBryster posted Fri, 25 November 2005 at 8:27 AM
You could maybe download some Poser Textures for animals and apply the jpgs ??????
cobwebdesignz posted Fri, 25 November 2005 at 9:25 AM
nice one, but I need to be able to change the image loads and use it with shodows ect, I have a version with a realy high polly count like this. as you can see the brown areas are ment to be fur.
vasquez posted Fri, 25 November 2005 at 9:39 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=324318&Start=19&Artist=vasquez&ByArtist=Yes
I did this once, it's made of a zillion of spheres with a "eyelashes"-like texture. It's a bit complicated and increases rendertimes to death, but maybe you can optimize it, and use it. vasq (thinking that pidjy's creature is really really really good looking)
cobwebdesignz posted Fri, 25 November 2005 at 11:48 AM
eyelashes like texture??? nice texture, love the image but 3days WOW
pakled posted Fri, 25 November 2005 at 12:06 PM
Lunariad.com has some fur mats, but I'm not sure how well they work for what you want..go by and see..
sackrat posted Fri, 25 November 2005 at 12:26 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=825242&Start=25&Sectionid=0&filter_genre_id=0&Form.S
Postwork is probably the way to go,............for me anyway,.......I use Photoshop7 and some hairbrushes by Bice(available in 2D freestuff section) go take a look at my image called "Rivals" in my gallery,.......the fur on the Bear was done in this manner.
"Any club that would have me as a member is probably not worth joining" -Groucho Marx
cobwebdesignz posted Fri, 25 November 2005 at 12:56 PM
Thats one hell of an image, I will look at those brushes, nice one thanks :)
marcfx posted Fri, 25 November 2005 at 1:20 PM
@sackrat Amazing postwork skills. I think anyone wouldn't find a plugin or programme to mimic as well as that fur. well done Marc (Most probably wrong but, would cost an arm and a leg!)
Smile, your dead a long time :)
Dann-O posted Fri, 25 November 2005 at 6:32 PM
What a great thread. I love the pics. Sackrat that is a awsome pic. Vazquez that is something like what I was originally thinking my daugheter loved your duck(her words not mine) . I am learning a lot abotu approaches to this. I am getting into organic modeling so it is soemthing I am very interested in.
vasquez posted Sat, 26 November 2005 at 5:08 AM
so this is another try. My old image took 3 days because of premium settings, DOF and soft shadows... this one took 3 minutes.
vasquez posted Sat, 26 November 2005 at 5:09 AM
wireframe
and the material I used, just put overa squashed sphere
RodsArt posted Sat, 26 November 2005 at 5:09 PM
Tried many times for good fur or hair in Bryce, always preferred postwork.
___
Ockham's razor- It's that simple
RodsArt posted Sat, 26 November 2005 at 5:13 PM
___
madmax_br5 posted Mon, 28 November 2005 at 11:34 PM
Only good way to do it in bryce is to tweak a volumetric material until you get the right results.
