mmoir opened this issue on Nov 28, 2005 ยท 12 posts
mmoir posted Mon, 28 November 2005 at 9:12 AM
bluetone posted Mon, 28 November 2005 at 11:58 AM
What format image file are you using? JPG's sometimes do this because of the compresion. Use PNGs instead, ot TIFs.
mmoir posted Mon, 28 November 2005 at 12:47 PM
I am using a tiff as the file type, PNG and jpegs don't allow you to save Alpha channels when you render . I did figure out a solution. My image was using the realistic sky and Skylite rendering option to light my scene. What I found is if you disable the realistic sky and put an image in the Background portion of the Scene effects tab of the properties tray and use this to light the scene instead of the realistic sky the fringe disappears. Thanks
sailor_ed posted Mon, 28 November 2005 at 1:17 PM
It sounds like your alpha is not pure black and white. Try converting it with the threshold tool in PS to get rid of any not quite pure blacks and whites.
bluetone posted Mon, 28 November 2005 at 1:23 PM
PNGs do allow for alpha channels, I have used it with a Carrara file before. I agree with sailor ed that for your use you need pure black and white for the alpha map.
mmoir posted Mon, 28 November 2005 at 3:16 PM
Bluetone, I tried in C4 and PNG is not an option, in C5 the Alpha channel is greyed out. I will try the threshold tool too,I played with a bunch of things in corel's mask outline settings with moderated success. I am very happy with the results of the preliminary render I did get , I will post the final image soon as I have to be done the image in a week. Mike
ren_mem posted Mon, 28 November 2005 at 5:04 PM
Did you have any kind of behavior or effects? I agree with the suggestions. I have seen this happen tho more so when doing animation.Also meant to mention antialias upped, but that is obvious and try no background also or the black or white as mentioned.
Message edited on: 11/28/2005 17:10
No need to think outside the box....
Just make it
invisible.
MarkBremmer posted Mon, 28 November 2005 at 7:59 PM
A good way to handle this is by using a Targa (.tar) file with an alpha mask in the color channel. Carrara automatically reads the alpha and applies it without the need to apply a seperate alpha in either the Alpha or Transparency channels. Mark
animajikgraphics posted Mon, 28 November 2005 at 9:54 PM
I use Targa or Tiff to render an alpha (RGBA) using C4Pro. Either work well for still or motion compositing.
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
dbigers posted Tue, 29 November 2005 at 9:00 AM
Depends on the target application. As Mark mentioned Targas carry the alpha information over well. Not just in Carrara but also when I use them in Lightwave. One thing that would be nice is to have the option of seperate alphas. In Lightwave I can save individual RGB frames in a number of different formats, I also have the option of saving the alpha information as seperate frames. That way I dont have to worry about the target application, I just select the alpha's to use as a mask. The masks always come out clean when I do it this way. One drawback is that it creates more files though.
goofball posted Tue, 29 November 2005 at 11:17 AM
If you can pre-multipy the alpha and color channels. That has always worked for me.
sfdex posted Tue, 29 November 2005 at 5:05 PM
I tend to render sequenced photoshop files with premultiplied alpha (sequenced, of course, only if it's an animation). From time to time I'll get this kind of fringe effect, but I get rid of it in AfterEffects with a simple choker. You could use the defringe effect in Photoshop, as well, I suspect.
