Estruch opened this issue on Nov 30, 2005 ยท 21 posts
Estruch posted Wed, 30 November 2005 at 11:55 AM
Exist a system for converted one geometry obz at obj? Thanks
geep posted Wed, 30 November 2005 at 12:08 PM
Yup, it's called Poser.
Hi Estruch,
Just go to:
[menu] "Edit" >>> "General Preferences..."
Click the "Miscellaneous" tab and ...
Under "Save Files" ...
Now, when you export an object, it will be saved as .obj and not .obz.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Estruch posted Wed, 30 November 2005 at 12:10 PM
Thanks
anastasis20 posted Wed, 30 November 2005 at 12:13 PM
While we're on the subject - is there anything like a utility or python script that can go through a runtime folder and convert all obz files into obj files without me having to do it all manually. Thanks
geep posted Wed, 30 November 2005 at 12:21 PM
Hmmmm, .... good question
Anyone? ... Anyone? ... Anyone? ... Bueller? ... Anyone? ...- - - - - -
WinZip ??? ... PKZip ??? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Wed, 30 November 2005 at 12:22 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Wed, 30 November 2005 at 12:23 PM
cheers,
dr geep ... :o]
edited 10/5/2019
zollster posted Wed, 30 November 2005 at 12:33 PM
"convert all obz files into obj files without me having to do it all manually." poser 6 can do that with a python. its in the utility folder called uncompressPoserFile.py
semidieu posted Wed, 30 November 2005 at 12:34 PM
First of all... there is a Python script that comes with Poser to compress or uncompress all files in a library; they are called "compress files" and "uncompress files"... Second, it's conmpressed using zlib. So you can open a compressed file with Winzip. It's very long, because you must do it for each files. Finally, if you need... i'm developing an application to manage the files in runtimes... I could add the features.
svdl posted Wed, 30 November 2005 at 12:36 PM
The script is supplied with P6. UncompressFiles.py has an option to uncompress the .obz files. Just run the script and select the folder that contains the .obz files you wish to uncompress. It's GZip by the way.
svdl posted Wed, 30 November 2005 at 12:37 PM
Oops, crosspost. Sorry.
Little_Dragon posted Wed, 30 November 2005 at 12:38 PM
You have to edit that script and set the unCompressOBJs flag to 1, first.
kuroyume0161 posted Wed, 30 November 2005 at 12:39 PM
The "uncompressPoserFiles.py" Python script (in Runtimes:Python:PoserScripts:Utility) can be run in Poser 6 and it will decompress everything, including OBZ to OBJ.
off.
-- Bjarne
Stroustrup
kuroyume0161 posted Wed, 30 November 2005 at 12:41 PM
All Great Minds Think Alike! Crossposted as well...
off.
-- Bjarne
Stroustrup
kuroyume0161 posted Wed, 30 November 2005 at 12:42 PM
svdl: GZip uses zlib! :)
off.
-- Bjarne
Stroustrup
geep posted Wed, 30 November 2005 at 12:50 PM
Ask and ye shall receive. ;=] Thanks all. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
svdl posted Wed, 30 November 2005 at 1:23 PM
"GZIP uses zlib" Absolutely right. Stupid me, just forgot it.
anastasis20 posted Wed, 30 November 2005 at 3:26 PM
Thanks for all the info everyone. I'm not too comfortable with Poser so all basic & obvious tips are welcome. This one is going to solve a lot of problems between Carrara Studio and Poser 6.
Estruch posted Wed, 30 November 2005 at 4:14 PM
Carrara and Transposer is not compatible with Poser 6?
anastasis20 posted Wed, 30 November 2005 at 4:37 PM
Sort of - you have to switch off all file compression and the external binary morph target option to use any Poser content. BUT Transposer doesn't like being pointed at Poser6.exe, it still wants Poser5.exe to read dynamic cloth and hair I upgraded from Poser 5 to 6, I've got both so I'm okay, but it's hardly the ideal solution.
R_Hatch posted Thu, 01 December 2005 at 1:23 AM
If you have UltimateZip, you can select several OBZ files at once and choose "extract to here", and it will spit out OBJ files in the same directory. This works fine in my case because I have always had "save compressed files" disabled, so the only ones I have are those that were included with Poser 6.
