Subject: ShaderSpider + 2nd Face Wow: Bonus Toolkit
PoseWorks opened this issue on Dec 01, 2005 ยท 1 posts
PoseWorks posted Thu, 01 December 2005 at 12:17 AM
ShaderSpider + 2nd Face Wow System Toolkit
I've spoken with Umut, and put together a free toolkit for users of both ShaderSpider and 2nd Face Wow System.
Installation
The SS6+2FWS package should be unzipped to your main Poser Runtime. ShaderSpider and 2nd Face Wow System are required to use the toolkit.
Using the SS6 Preset
The SS6 preset will set up material groups for any second face created by the 2nd Face Wow System. To apply this preset:
  1. Select your second face figure in Poser.
  2. Load the ShaderSpider wacros.
  3. Click Edit Groups to launch the group editor.
  4. On the group editor window, click "IMPORT" and select "2ndFaceWow.ss6".
  5. Click "SAVE".
Now Copy To Surface Group and Copy To Mapping Group will work properly with the second face.
Using the "2nd Face - Grab Parent Material" Wacro
This wacro copies all of the nodes and settings, except for those related to transparency, from the parent figure to the second face. To use this wacro:
  1. Select the desired material on your second face figure. Your second face must be conformed.
  2. On the wacros palette, click the "User Defined" button and choose "2nd Face - Grab Parent Material".
Now the material will have all of the textures and settings of the parent figure available to use in your shader.
Using the Auto Match Script
Auto Match to 2ndFace allows you to control all of a figure's facial morphs from the second face. Warning: This script may slow down the scene.
  1. Conform the second face to your figure. Inject all of the morphs you wish to use for both figures.
  2. Select the second face.
  3. Go to File > Run Python Script and browse to "Runtime:Python:poserScripts:2ndFaceWowSystem:Auto Match to 2ndFace".
  4. Morph the face as desired.
