Forum: MarketPlace Showcase
Subject: "2nd Face WOW System" and "ShaderSpider" StRoNgEr ToGeThEr
umutov opened this issue on Dec 01, 2005 ยท 1 posts
umutov posted Thu, 01 December 2005 at 3:00 PM
  ![th_ss6.jpg](http://www.poseworks.com/images/th_ss6.jpg)
ShaderSpider + 2nd Face Wow System Toolkit
**Users of both 2nd Face Wow and ShaderSpider can benefit from a free toolkit that lets you combine the power of these two products. The toolkit contains: A ShaderSpider preset for 2nd Face Wow-generated faces, a wacro that lets you import properties of the figure's head materials to the second face, and a Python script that keeps the two skins' morphs in synch.
ShaderSpider is now available from DAZ**
ShaderSpider upgrades, patches and tutorial available from POSEWORKS
2nd Face WOW System (Unimesh)
Price: $13.96 onsale.jpg
By umutov, Dimension3D
PC Only
WHAT IS IT?
2nd Face Wow System (Unimesh) creates a conforming figure that adds a layer for overlay textures to the head. The figure has the same geometry, morphs, morph injections, and UV-mapping as the original figure. The material regions are altered to allow the combination of several overlays for different regions of the head, e.g. make-up for lips, eyes, and cheeks.
2nd Face Wow System (Unimesh) is a true Revolution in Poser. With 2nd Face Wow System (Unimesh) you will never need those "This for V3, that for M3" kind of products again. Basically there are a few good merchant resources out there, which 99% of the add-on character sets for Unimesh Figures are made from. You are actually keeping on buying the same texture with a different blush or a different lip stick over and over again. By 2nd Face Wow System (Unimesh) you will be able to render Makeup's - Tattoos - Facial Hair - Painted Hair - Facial Jewelry - Scars and anything your imagination desires, on the Unimesh Characters.
BENEFITS
Think that you have made a very nice Makeup for one of your textures, but you want to use the same makeup for other textures you have. Let's say you have 10 textures. You will have to lay that same Makeup on to those 10 textures and save them. This will take huge space on your HDD and Runtime Folders. The example we have is with 1 Makeup. Let's make the scenario with 10 Makeup's being used with the 10 textures we have. That means 100 textures. Can you imagine how much space that will take? Things become even worse if you want to mix several makeups, say combine the eye shadow of one makeup with the blush of the other, or you want to change the color a bit.
With 2nd Face Wow System (Unimesh) all you will have to do is, make your Makeup and apply it to the Conforming Second Face 2nd Face Wow System creates. You will be able to use it with all of your Unimesh Figures and Base Textures you have without the need for 100's of textures. You can even apply different textures to different material zones and adjust colors directly in Poser.
**WHAT'S INCLUDED?**
**1) 2nd Face Wow System Software (Windows Only)
  1. Presets for DAZ Unimesh, DAZ Unimesh M3, DAZ Unimesh RR, and the Girl
  2. 8 Preset Mat Poses (Lip Stick - Blush - Eye Liner - Tattoo - Bindi - Eye Shadow - Facial Hair - Hair) + 1 Reset Mat Pose
  3. Software Tutorial and Makeup Creation Tutorial**
**FREQUENTLY ASKED QUESTIONS**
Q**) Which characters are supported by 2nd Face Wow System (Unimesh)?
A) All Unimesh characters: Victoria3, Michael3, Stephanie3, David3, Aiko3, Hiro3, the Freak, and compatible characters. In addition, the reduced resolution versions of Victoria3 and Michael3. The Girl is also supported.**
Q**) Does this program support all the morphs for the Unimesh Characters?
A) Yes, 2nd Face Wow System (Unimesh) simply create a clone of the head which supports all the morphs and morph injctions for Unimesh Characters.**
Q**) How much time does it add to the rendering process?
A) This depends on many things. All in all, it's similar to adding other conforming figures.**
Q**) Since Poser 5 and 6 supports texture overlaying by Shader Nodes, why would I need this program?
A) In the shader tree, you have to add the overlays manually. This requires some experience with shader trees, especially if you want to mix several overlays for one material zone. With 2nd Face Wow System (Unimesh), it's just the common Poser style - add a figure, conform, apply mat poses.**
Q**) Will 2nd Face Wow System (Unimesh) work with Jessi - Miki and other characters which are Non-Unimesh?
A) Extensions for other figures will be available soon.**
Q**) Does 2nd Face Wow System (Unimesh) work with MAC Systems, if "NO" will it be supported?
A) Currently the application is Windows only. We are considering a MAC version.**
Q**) Does 2nd Face Wow System (Unimesh) work with all WINDOWS versions?
A) The application works with Windows 95-XP, XP 64 has not been tested.**
 **Product Reviews** 12/01/05 - **[sflayer](http://www.renderosity.com/homepage.ez?Who=sflayer)** What a great idea! I love this package, and I am excited for the versatility it's going to add to my favorite textures. Texture artists out there (Rhiannon, Samil, are you listening?) need to make some makeup packs for this set!  12/01/05 - **[tlc](http://www.renderosity.com/homepage.ez?Who=tlc)** Great product - easy to use. For shader-spider owners there's an update so you can use the two in tandem making life even easier if that's possible. More character options, such as Miki will be appearing soon along with more texture packs. Even the most technophobic of users will be able to use this product and get great results in their renders - 5 star product all the way.  11/30/05 - **[cathsyl](http://www.renderosity.com/homepage.ez?Who=cathsyl)** I'm very happy.I'm only user and not a creator. Your product is bringing me a lot more flexibility.It is very easy to use and I can't wait for more add-on to be available.  11/30/05 - **[karanta](http://www.renderosity.com/homepage.ez?Who=karanta)** Great product!  11/28/05 - **[RFreise](http://www.renderosity.com/homepage.ez?Who=RFreise)** This is really neat now I don't have to have multiple copies of a texture that I have modified works very well  11/28/05 - **[Khrys](http://www.renderosity.com/homepage.ez?Who=Khrys)** This is a very creative solution for those of us who love doing make up for our characters, but hate having 20 different versions, just to make sure it fits all our texture sets. It's fairly simple to use, and is, in many ways, like having a miniature version of the Aiko or Hiro3 bodysuits, just for the face. Catch it while it's on sale, then grab the add ons as they come out.  11/28/05 - **[imandos](http://www.renderosity.com/homepage.ez?Who=imandos)** A great five star product. The product is easy to use and works really well. I can hardly wait to see new products using this great idea. Guarie already has out two great products supporting this one and there should be many more, from scars to tattoos. The possible uses seem endless. A great new idea and product. Best, Imandos    **[IF YOU WOULD LIKE TO BUY THIS PRODUCT, PLEASE FOLLOW THIS LINK TO IT'S STORE PAGE](http://market.renderosity.com/softgood.ez?ViewSoftgood=42376)**
