Stan57 opened this issue on Dec 01, 2005 ยท 3 posts
Stan57 posted Thu, 01 December 2005 at 5:05 PM
Hi All, New user here I am trying to use the !jessi body morphs and am getting this error Cant open script for reading (PEPythonEngine::Doscript) Thanks in advance Stan
Jack Of All Trades Master Of None
Jules53757 posted Fri, 02 December 2005 at 2:18 AM
This usually happens when the location for the Python script is wrong or the filename is not correct. I expect yopu are trying to inject the DNA morphs. In this case, when you are working with multiple runtimes or have choosen an other then the standard location, you have to edit the CR2 manually. Check also the Python directory if it's in the main runtime with this location; RuntimePythonposerScriptsDnaFBMaddJessiAllTargetParms.py Filename is only one example call from the Bodymorphs,
Message edited on: 12/02/2005 02:25
Ulli
Stan57 posted Fri, 02 December 2005 at 5:07 AM
Ok the files are in the download section,runtime. Should i reinstall it to the reg poser runtime?
