Forum: Community Center
Subject: trouble with thumbnails?
shadowking1957 opened this issue on Dec 02, 2005 ยท 11 posts
shadowking1957 posted Fri, 02 December 2005 at 8:40 AM
Hi I have found that when i try to put a thumbnail on the galleries it will not load it says below 15 kb, what is the correct size to use and resolution settings, i have adobe photo and the renders are from poser?? Is there a best set size and what is it? I check my settings and its below 15 but will not load. Am i doing something wrong? thank you for your time as always in replying, the members here are fantastic at helping beginners. Tony
Elminster_ZK posted Fri, 02 December 2005 at 8:59 AM
Are you sure you're using a jpeg file? Usually a 190x190 jpeg at about 60-70 percent works fine...
"Walk down the right back alley in Sin City, and you can find anything."
shadowking1957 posted Fri, 02 December 2005 at 9:21 AM
Hi Elminster I tried it and still would not work the image size was pixel dimensions 9.52 width 50 pixels heigh 65 pixels doucument size width 0.85cm height1.1 cm resalution 150 pix/inch bicubic ??? what is wrong?? I have tried all my images and still get thumbnail too big??? thanks for thr reply.
KarenJ posted Fri, 02 December 2005 at 9:35 AM
Hi Tony, Are you getting an error message when you try to upload to the gallery? If so, what is it?
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
shadowking1957 posted Fri, 02 December 2005 at 10:00 AM
Yes it is thumbnail size too big must be 15kb
cynlee posted Fri, 02 December 2005 at 10:32 AM
are you renaming the thumb different then the main image? like imagethumb.jpg?
shadowking1957 posted Fri, 02 December 2005 at 10:37 AM
yes I have tried all sorts lol.
KarenJ posted Fri, 02 December 2005 at 10:47 AM
Can you upload the thumb here, so we can check the formatting?
"you are terrifying
cynlee posted Fri, 02 December 2005 at 10:53 AM
in PS do you use the "save for web" feature? works best for images & thumbs
& something i've heard other members do who seen to have this problem is they've been uploading the main image then go back & use the [edit] under the "non-thumb", uploading the thumb separate
Message edited on: 12/02/2005 10:53
shadowking1957 posted Fri, 02 December 2005 at 1:10 PM
Thanks to all, cynlee I saved it as a web and it loaded np, thanks so much. I will edit my other pieces and feel a bit more successful thank you all again. Tony
cynlee posted Fri, 02 December 2005 at 1:15 PM
you're welcome Tony.. glad we got it to work for you ;]
