Amduceus opened this issue on Dec 02, 2005 ยท 9 posts
Amduceus posted Fri, 02 December 2005 at 11:02 AM
Okay, heres the thing, I understand how to load morph targets into my body parts in poser, but I don't know how to make them come in at the right sized obj. file to keep them from making the body part ridiculously huge when I use them. Can anyone help me on that?
DCArt posted Fri, 02 December 2005 at 11:04 AM
When you create a morph target, you have to make sure that you don't make any other scaling changes to the OBJ file. You have to keep it at the original size, and also keep it in the original position. After that, the only vertices that you should move are those that you want to move when you use the morph dial.
Message edited on: 12/02/2005 11:05
Amduceus posted Fri, 02 December 2005 at 11:09 AM
Okay, so how do I keep the obj properly scaled if I want to build my morphs in Wings3D or something?
DCArt posted Fri, 02 December 2005 at 11:16 AM
I'm not familiar with wings. But generally there are a couple of ways to approach it: (1) Import the original OBJ file (the one in the Geometries folder) into Wings and work with that. DO NOT overwrite the original OBJ file when you save your morph. Save it to a different file name or different folder. (2) Make sure that your figure is in the Zero Position (no scaling, morphs, or other translations set) before you export the OBJ file or any body part from Poser. When you import into Wings, make sure that Wings does not automatically rescale it. I'm not familiar with Wings, but check to see if anything in the Import dialog, or the Export dialog relates to increasing or decreasing the size of the OBJ file. If it increases the scale when you import, you will have to decrease the scale appropriately when you export. In other words, if you scale the figure up by ten times when you import into Wings, you'll have to divide it by ten when you export it for Poser. Hope that makes sense.
Amduceus posted Fri, 02 December 2005 at 11:18 AM
I'll try that!! thank-you.
geep posted Fri, 02 December 2005 at 11:26 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1843595
Hey Deece, Whar's me book? (big grin) ;=] ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
DCArt posted Fri, 02 December 2005 at 11:34 AM
It's in the publisher's hands now. 8-) I will contact you as soon as I receive my copies. 8-D
(And don't forget to read the dedication page! LOL) PS - not sure that it will be before Christmas. Perhaps sometime in Jan.??
Message edited on: 12/02/2005 11:35
geep posted Fri, 02 December 2005 at 11:47 AM
Thanks Deece,
Oh goody .................... Christmas in January!
I just lubs late Xmas presents.
Looking forward to it with great anticipation.
Now, maybe I can finally learn something about Poser 6.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Amduceus posted Fri, 02 December 2005 at 11:54 AM
Cool thanks, I'll check it out!!
