Forum: Carrara
Subject: another easy question for the pros..
HopsAndBarley opened this issue on Dec 04, 2005 ยท 7 posts
HopsAndBarley posted Sun, 04 December 2005 at 10:32 AM
HI all, I want to apply a label to the beer bottles in my Robots-Playing-Cards image. In the test image here you see two bottles. The label on bottle 2 is a separate, thin, object twisted to fit around the bottle. The label on bottle 2 is a rectangle layer added in the texture tree. I would like to use method number 2. But it looks like the label on number 2 is taking on the transparency qualities of the bottle, which I don't want. Is there a way to stop it from doing that? Cheers, H&B
HopsAndBarley posted Sun, 04 December 2005 at 10:33 AM
Here is a screen shot of my texture tree for the number 2 bottle and label.
bluetone posted Sun, 04 December 2005 at 10:39 AM
For your 'Rect layer' assign a transparency of 0. If you don't assign something, then Carrara will take on the top shaders assignments. Hope this helps!
HopsAndBarley posted Sun, 04 December 2005 at 10:45 AM
Thanks. That did the trick. I did the same thing for relfection and others. It makes all the difference. Thanks again. H&B
bluetone posted Sun, 04 December 2005 at 10:50 AM
Your welcome... one of those 'gotchas' that make so much sense... AFTER you've already torn all your hair out for 3 hours in the middle of the night... ok... just my personal experience... ;)
ren_mem posted Sun, 04 December 2005 at 2:53 PM
Yeah, I have had some fun myself w/ transparency and layers in carrara :D
No need to think outside the box....
    Just make it invisible.
ShawnDriscoll posted Sun, 04 December 2005 at 10:32 PM
I didn't know that. I assumed none meant 0%. No wonder.
